Home > Maintenance & Mods (L322) > 2010MY+ CCF Editing
Page 4 of 5 <12345>
neilly
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
This morning I did the following.
Changed the alarm to sound with horn
One press superlock enabled.
Added the digital MPH on the speedo.
Turned on the std fairly light DRLs.
Cheers
Post #576683 20th Dec 2020 12:01pm
kevinp
Must have another go at my drl's. When I tried last time they didn't work and it also stopped the electric windows going up and knocked out the distance warning!!
Post #576684 20th Dec 2020 12:20pm
neilly
For some reason, it told me the update had failed, but in reality the changes worked.
Cheers
Post #576687 20th Dec 2020 12:41pm
TJRL
Cheers
Any tips for an ID tool novice on how you did this? 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD Sad
1960 Land Rover SII SWB SW
2020 BMW R1250 RT LE
2021 Triton ST-125 (Monkey Bike)
Post #576726 20th Dec 2020 5:32pm
DrRob
Same here today
Digital speedo
DRL fairly lights
IID prompts you through it but boy does the dashboard go a bit bonkers.
Date and clock need adjusting afterwards and radio channels stored Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #576741 20th Dec 2020 7:26pm
neilly
Also the windows need to be rest to one push close.
But was surprised when it said upload failed and yet it completed.
The dash gives you heart palpitations the first time it happens.
I had read somewhere on her eto get out lock / unlock a few times and it resests itself.
In answer to the question above as you say, the IID takes you through it,
select what your want to change and follow the directions on the screen.
Make sure you have a good battery .
Cheers
Post #576745 20th Dec 2020 8:21pm
DrRob
Yes, I locked it, restarted and all was good. Loads of warnings flashed up before that saying abs, Tc etc not working but locking and then unlocking and starting up sorted it all out.
Will do windows one touch. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #576749 20th Dec 2020 8:56pm
DrRob
I had mine on the CTEK for a few hours beforehand. Afterwards I checked the %age state on the IID. 85%. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #576794 21st Dec 2020 11:32am
RichTD6
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Got the IID tool plugged in this morning and activated the digital MPH display on my dashboard! Happy days! 🙂
Much easier than I expected it to be! 2012 Westminster TDV8 4.4 Indus Silver
GAP IID Bluetooth Tool
Previous Range Rovers:
2005 L322 Vogue SE TD6 Zambezi Silver
1995 P38A HSE Epsom Green
1988 Classic Vogue EFi Cassis Red
1973 Two Door Tuscan Blue
Post #577066 23rd Dec 2020 12:55pm
DrRob
Got some LED number plate light bulbs to fit but will use IID to disable the cold test to avoid them flashing as part of a bulb check:
Fwd to 3:40ish
?t=220
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #577070 23rd Dec 2020 2:15pm
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
Has anyone enabled the amber front markers?
Similar to the L405?
Post #577092 23rd Dec 2020 11:02pm
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
Is it possible to have the digital readout as kph with the main dial in mph?
Every other vehicle I've owned has had both scales on the speedo and I find it odd that you can have either/or but not main mph and a subsidiary kph somewhere!
Cheers,
Dunc.
EDIT:
I've done it! It was actually very straightforward.
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #586596 7th Mar 2021 2:25pm
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
Speedo change back to mph.
Hi Dr Rob
Need help to get main speedo back to mph? Got the digital reading for mph but want to get the speedo back to mph also for day to day use. Help appreciated. Big Cry Big Cry
Thanks Dave
Post #587166 12th Mar 2021 11:35am
DrRob
Try the onboard menu. If not, in another part of IID menu for CCF update as per digital window... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #587172 12th Mar 2021 12:24pm
Nylands
I’ll try another go at it. Sometimes pays to take a break. Let you know if successful.
Dave
Post #587178 12th Mar 2021 1:37pm
Page 4 of 5 <12345>
