![]() | Home > Technical (L322) > No Parking Sensors |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 ![]() ![]() ![]() |
Interesting cheers Many thanks
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
Got to say that NavCoder is better for diagnosing PDC faults on early (2002-2004.5) BMW ffrr's. For a kick off it shows all the sensors and what they are seeing! Yesterday I couldn't spell Engineer... Today I are one!
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
Not helpful, haha , more money, when I have just bought the Gap tool , however having said that my problem is sporadic, and what I cannot understand and what may have happened now is that when I select live values and the P button on with continuous tone the one sensor that will not accept a tick is the front inner left, is this telling me of the intermittent fault that I keep getting , because of now the sensors are normal again and showing no faults. Maybe Gap can show some light on this.
Swap the sensor with another one and see if the fault moves, if it does then you need a sensor, if it stays inner left it's the loom!! Yesterday I couldn't spell Engineer... Today I are one!
When it next goes to continuous tone I will , that won’t be lon , like tomorrow morning . Cheers Pat |
Matt Pearce Member Since: 10 Jan 2018 Location: Bedfordshire Posts: 25 ![]() ![]() ![]() |
if you were down my way youd be welcome to use mine..
When the car starts up every day things are fine then it’s back again , so I haven’t got long to wait every day!
Hey Pat im not sure how much All comms is for the latest kit and as said there are other diagnostic plug ins im sure that are better, but when im working with all comms i can see the way this guy storey has put it together..
Many thanks for your honest thoughts on the diagnostic, normally I wouldn't hesitate on your advice on All Comms, but I have just bought the Gap IID TOOL ,and picked up All Comms in my research , its sounds very good after reading all about it ....dam!
I have done a raid bit of testing today with nothing conclusive, on the live values on the park module it has come up the the left sensor was only reading 25mm . So I have swapped it with the right sensor , easier access, and now when I do live values again it says the right inner and right are reading with small distance parameters. Can I conclude from that these are faulty. Am I doing this correctly. |
Pat, although i have changed bumper etc, i have never really had @ny problems with the Parking sensors but reasonably it Looks like you have identified the fault.
Just saw your reply when I have just browsed for replacements, wary of cheap alternatives , anyone got access to genuine part number number please. |
Pat just saw one on Ebay genuine landrover LR038084
Ok bought two sensors off Amazon , Part.no. ydb500301 , hopefully that number is correct , but tie up with the ebay no.?
