Home > Technical (L322) > No Parking Sensors
Page 2 of 3 <123>
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Interesting cheers Many thanks
Paul
Post #463439 5th Jan 2018 7:10pm
miggit
Got to say that NavCoder is better for diagnosing PDC faults on early (2002-2004.5) BMW ffrr's. For a kick off it shows all the sensors and what they are seeing! Yesterday I couldn't spell Engineer... Today I are one!
Post #463594 7th Jan 2018 9:08am
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
Not helpful, haha , more money, when I have just bought the Gap tool , however having said that my problem is sporadic, and what I cannot understand and what may have happened now is that when I select live values and the P button on with continuous tone the one sensor that will not accept a tick is the front inner left, is this telling me of the intermittent fault that I keep getting , because of now the sensors are normal again and showing no faults. Maybe Gap can show some light on this.
Sorry I may have repeated myself in this thread but just adding to this frustrating issue!
Post #463709 7th Jan 2018 10:19pm
miggit
Swap the sensor with another one and see if the fault moves, if it does then you need a sensor, if it stays inner left it's the loom!! Yesterday I couldn't spell Engineer... Today I are one!
Post #463714 7th Jan 2018 11:17pm
alfapat
When it next goes to continuous tone I will , that won’t be lon , like tomorrow morning . Cheers Pat
Post #463716 7th Jan 2018 11:23pm
Matt Pearce
United Kingdom 2003 Range Rover HSE Td6 Oslo Blue
parking sensors not working..
Hey have you considered buying All Comms 3 for L322
this tool has @ comprehensive model specific fault finding section on Almost every system including Parking sensors.
it will give you a far more specific indication of your fault then any other diagnostic plug ins this side of Rovercom system
whatever best of luck ( im not a shareholder in All Comms )
Matt..
Post #464034 10th Jan 2018 6:01pm
Matt Pearce
if you were down my way youd be welcome to use mine..
dont you just hate waiting for the fault to re occur..
Post #464037 10th Jan 2018 6:06pm
alfapat
When the car starts up every day things are fine then it’s back again , so I haven’t got long to wait every day!
Thanks for you offer , by the time I got to Bedfordshire I probably would have spent the cost of the All Comms .... or have I?
I’ll look it up .
Cheers Pat
Post #464082 10th Jan 2018 9:37pm
Matt Pearce
Hey Pat im not sure how much All comms is for the latest kit and as said there are other diagnostic plug ins im sure that are better, but when im working with all comms i can see the way this guy storey has put it together..
it covers the most potentially expensive bits like EAS, ABS Transfer Box and Body control and Engine management etc. in a bunch of different ways , and although you still find yourself scrathing your head as to what the next step might be..
it does really get your head into the logic of it all.
i prob@bly log on @ couple of times a month even when i dont have any issues just to make sure i have faults coming up..
and its kind of re assuring.
ive actually had the car for around six years and for most of that time without any diagnostic gear..
So when a problem came up id bite my nails but have to take it to an independent garage hoping that they would be fairly honest with me, but i must admit theres been a few times when ive had things replaced that simply had nothing to do with the problem. and i can see that now..
Now at least with my bit of kit i am usually fairly close to the probable cause rather than relying completely on the garage.
Anough more than enough from me, .. B3 great to hear that you sort your sensor issue out..
Cheers
Post #464107 11th Jan 2018 12:14am
alfapat
Many thanks for your honest thoughts on the diagnostic, normally I wouldn't hesitate on your advice on All Comms, but I have just bought the Gap IID TOOL ,and picked up All Comms in my research , its sounds very good after reading all about it ....dam!
Oh well I shall have get some advice from Gap as I THINK I am quite close , watch this space , I will post when I find out,
Cheers Pat
Post #464118 11th Jan 2018 7:05am
alfapat
I have done a raid bit of testing today with nothing conclusive, on the live values on the park module it has come up the the left sensor was only reading 25mm . So I have swapped it with the right sensor , easier access, and now when I do live values again it says the right inner and right are reading with small distance parameters. Can I conclude from that these are faulty. Am I doing this correctly.
Post #464549 14th Jan 2018 5:00pm
Matt Pearce
Pat, although i have changed bumper etc, i have never really had @ny problems with the Parking sensors but reasonably it Looks like you have identified the fault.
If you do look to purchase new ones do search around because prices for the same item vary greatly especially on EBay..
but obviously better new than ‘Pre Owned’.
( as if you would)!
whatever best of luck , Steve..
Post #464597 14th Jan 2018 10:15pm
alfapat
Just saw your reply when I have just browsed for replacements, wary of cheap alternatives , anyone got access to genuine part number number please.
Post #464600 14th Jan 2018 10:59pm
Matt Pearce
Pat just saw one on Ebay genuine landrover LR038084
£15..
free p&p
Steve
Post #464605 14th Jan 2018 11:29pm
alfapat
Ok bought two sensors off Amazon , Part.no. ydb500301 , hopefully that number is correct , but tie up with the ebay no.?
Aye looked at your find Matt , they looked different , good spot Thanks for your help , fingers crossed! Thumbs Up
Post #464794 16th Jan 2018 6:54pm
Page 2 of 3 <123>
