![]() | Home > Technical (L322) > 2007 TDV8 weird goings on... |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Sounds a bit like the scary bit in 'Psycho'.
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
David...mine had a similar electrical issue which eventually turned into a near dead battery situation with all lights coming on and then flashed off then on then dead. The LR assist engineer diagnosed a faulty alternator that had gradually gone from charging the battery to drawing current from battery. A new alt was fitted and they said the battery was ok and has been for 18 months.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3155 ![]() ![]() ![]() |
Paul,
Anybody know what the noise David recorded and posted to YouTube might be on both our TDV8's circa 2007/08
Is it the squeak squeak noise x 5 or 6 at the end? If so, its the EGR's absolutely normal... |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 612 ![]() ![]() ![]() |
I'd make sure everything is turned off. Wondering whether it could be something to do with air con cooling down. Sounds like air bleeding through something. Maybe try with suspension at different heights? |
That's it Craig...engine off then squeak x 6.
Not sure why they make the noise Paul, but they all do it and i know its the EGR valves that are doing it |
Ahh...muchos grassyarse Craig. |
Thanks Craig.
Your very welcome gents |
Craig,
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 165 ![]() ![]() ![]() |
Hi Craig,
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 904 ![]() ![]() ![]() |
Just noticed my 2008 TDV8 makes the same noise after switching it off.
