Home > Technical (L322) > 2007 TDV8 weird goings on...
dhallworth
A friend of mine has a 2007 TDV8 which has covered 90k miles.
He started having electrical issues with it where it would go into limp mode and show a load of electrical warnings on the dashboard. The battery was replaced with a new 110ah battery and the faults seemed to clear for about a week. When we had the heat wave last week all of the faults returned when he was running the air con, headlights and everything at the same time.
The warnings are: Engine fault, HDC fault, Air Suspension fault, & Transmission Fault.
When I was with him the other day I noticed that it makes a funny noise when the car is switched off. It's like a screeching noise after the engine has stopped. The viscous fan has completely stopped turning when it makes this noise. I video'd it and have stuck it on YouTube:
I don't know if these are related or not but it's a strange noise. When switched off the voltage on the new battery is 12.4v, running with some electrics turned on it's 14.4v however it does seem to raise to 15.4v with everything electrical turned on which to me seems to high.
I know the alternators are a common fault on the TDV8 but was just wondering what other peoples opinions were as I've heard they're not that nice a job to change.
The other problem with this car is it seems to loose coolant. The oil is clean, there's no steam from the exhaust and no obvious coolant leaks from the car. However there are bubbles that appear to come into the heater tank around the bleed screw in it.
Is it possible for low coolant to trigger the faults above and put it into limp mode? I don't think it is but thought I'd ask just to be sure.
Thanks in advance Thumbs Up
Post #273071 27th Jul 2014 2:53pm
Sounds a bit like the scary bit in 'Psycho'.
Is Norman or his mother hiding in there?
Post #273078 27th Jul 2014 3:32pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
David...mine had a similar electrical issue which eventually turned into a near dead battery situation with all lights coming on and then flashed off then on then dead. The LR assist engineer diagnosed a faulty alternator that had gradually gone from charging the battery to drawing current from battery. A new alt was fitted and they said the battery was ok and has been for 18 months.
I also get that exact noise ( intermittently lasting up-to 10 seconds after engine shut down) and thought nothing of it really, other than a fan slowing down, but it never does it when it's been in for service work, so it's never been diagnosed...would be interested to hear opinions on that myself.
Ps sorry for the edits...bloody Ipad! GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #273085 27th Jul 2014 3:55pm
dhallworth
Paul,
It's definitely a strange noise and not one I'd heard on our old TDV8 before we sold it.
Post #273174 27th Jul 2014 11:28pm
paulmoran2
Anybody know what the noise David recorded and posted to YouTube might be on both our TDV8's circa 2007/08
Post #273274 28th Jul 2014 4:06pm
Is it the squeak squeak noise x 5 or 6 at the end? If so, its the EGR's absolutely normal... Thumbs Up
Post #273306 28th Jul 2014 7:14pm
sako243
I'd make sure everything is turned off. Wondering whether it could be something to do with air con cooling down. Sounds like air bleeding through something. Maybe try with suspension at different heights?
Post #273307 28th Jul 2014 7:16pm
paulmoran2
That's it Craig...engine off then squeak x 6.
Why does it do it? What's the mechanics of the noise? GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #273312 28th Jul 2014 7:31pm
Not sure why they make the noise Paul, but they all do it and i know its the EGR valves that are doing it Thumbs Up
Post #273316 28th Jul 2014 7:55pm
paulmoran2
Ahh...muchos grassyarse Craig. Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #273324 28th Jul 2014 8:45pm
dhallworth
Thanks Craig.
Certainly put both our minds at rest! Just need to get to the bottom of his electrical goings on now!
Post #273334 28th Jul 2014 9:33pm
Your very welcome gents Bow down
Post #273340 28th Jul 2014 10:00pm
dhallworth
Craig,
Does that mean that the EGR valves are moving quite freely and aren't coked up or likely to daily imminently?
Post #273341 28th Jul 2014 10:04pm
Dijit
Scotland 2007 Range Rover Vogue TDV8 Java Black
Hi Craig,
If I'm reading you correctly you're saying the noise in the video is normal and definitely comes from the EGRs. Would you know if a 3.6 TDV8 didn't make that noise if it was an early sign of problems with the EGR valves? Rehab is for quitters!!!
RR 2007 3.6 TDV8 Java Black *
RR 2007 3.6 TDV8 Zermatt silver *
RR 2000 P38 4.6 Met red *
Mercedes 300TE 4-Matic *
Jaguar 420 (1969) *
Nissan 300Z
Citroen XM 2.5TD X 6
Bentley Continental R
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Am told the ones with a * are to be offered for sale! 😳
Departed
LR 1992 110 2.5TD
RR 2000 Holland & Holland 4.6 LPG
RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue
RR 2002 4.4 V8 Zambesi Silver
Post #273379 29th Jul 2014 9:02am
mpirie
Just noticed my 2008 TDV8 makes the same noise after switching it off.
Rolling Eyes
Could it be a gremlin trying to escape and it being proof that coal burners are the work of Satan?
(said by someone who's asked for an SC for his next birthday from SWMBO)
Post #273987 1st Aug 2014 9:34pm
