![]() | Home > My Range Rover > My Giverney Range Rover |
Eugene here is your car in 2012+ guise but with different wheels:
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3785 ![]() ![]() |
Gaz your rear Vogue badge is in the wrong position - it's a couple of inches too high ![]() |
Good spot blame Lee Clark |
Clarks Premier the company that does my 2012 Conversions. |
The only difference I can see is the headlights on the 2012 has a dark "background". And this 2012 seems to have colour coded side gills. MY 2010 5.0 SC Galway green and sand interior!!
not sure it is... all 2012
etc..... Last edited by Gazellio @ Prestige Cars on 2nd Jul 2014 3:45pm. Edited 2 times in total |
Yes Dark Headlight/Rear Light Backgrounds, Black Grille Surround, Titan Splitter & Fog Surrounds, Coded Side Grilles & Door Handles. |
If you look at the pics above the badge usually lines up with the middle of the tail light i.e. level with the gap between the two light circles - if you look at yours it's higher than it should be |
Only Marginally but yes |
Agreed I also like the look of the std car - however I think flaps and steps also look good on lighter coloured cars - not too sure on the darker colours 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
^^ tee hee! That ones in the wrong position too |
What few realise is Steps/Flaps really FATTEN the sleek lines of the L322. You need the slim waist and lots of ground clearance between the wheels. Great to see the tyres from behind too.... |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Jeez, you guys are OCD pedants.
