Home > In Car Electronics (L322) > Bosch S6 AGM
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
Bosch S6 AGM
Current battery fitted to my 03 TD6 is a yuasa, don't know how long it's been on the car but it seems to be showing signs of failing.
Voltage drops to 12.0 if not used for a day or two and the indicator has gone black.
I should also mention that the voltage drops even when disonected from the car, so there is no parasitic current draw.
I can get a Bosch S6 AGM for a great price, but what are they like, has anyone got one?
Post #263506 5th Jun 2014 9:58pm
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I got the equivalent 110 varta from battery megastore
Less than £100 delivered Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #263514 5th Jun 2014 10:37pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
AGM batteries are for stop start vehicles I believe. An S% is probably better value for you and will have the same amount of power to crank the car over. 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #268676 2nd Jul 2014 6:53pm
iphs
Thank you Sir. I am hoping to fit 2 of these, one in the boot space with a split charge relay. Fitted in much the same way as Joe90 has fitted one.
I am hoping that this extra power source will help to take care of the power drain when the car is not used for a few days. leaving plenty of power in the main battery to crank the engine. I HOPE!!
Rolling Eyes
Post #268729 2nd Jul 2014 8:50pm
