Home > Maintenance & Mods (L322) > Side Step Repairs
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Side Step Repairs
Guys
Can anyone advise if they have ever taken original steps with mudflaps off and not had to do paintwork under the mudflap or do they rust where they trap the mud and rain?
My 2004 has had original steps and combined mudflaps fitted from new. The 2 graphite grey strips that run down the sides are broken. I see they sell replacements @ £80 each. New steps are £150!!
Alot of people say the L322 looks better without them, so was wondering about unbolting them this weekend to take a look, but am guessing there is going to be rust under where the mud flap fits? Are they just 2 bolts into the chassis and then unscrew the mudflap?
Cheers
Tel Accept, some days your the pigeon, some days your the statue!
Post #267784 28th Jun 2014 1:02pm
Googsy
It all depends. It doesnt rust were you mention but sometimes after removing the flaps there will be a line where the mudflap sat against the panel. I reckon theres a good chance of rubbing this line with polish and it should remove most if not all of any evidence. You wont know until you try though as its dependent on how tight the flaps are against panel. Hope that makes sense. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #267786 28th Jun 2014 1:09pm
Boydonegood
Cheers Fella!
Yeah total sence! Will have a go tomorow and see if i like it bare. If not ill have to order a set of copy steps i guess. As i say the 2 repair strips are £160! New steps are £150 ish for copies or £250 for Gen
Cheers Accept, some days your the pigeon, some days your the statue!
Post #267788 28th Jun 2014 1:12pm
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Be interested to hear how that goes as I've been toying with the same idea. "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #267789 28th Jun 2014 1:16pm
if you remove the flaps you'll have two small holes showing in the lower panel... ... - .- -.
Post #267790 28th Jun 2014 1:18pm
Boydonegood
Oh really? Crying or Very sad
Was kinda hopeing they screwed through the wheel arch lip .
Oh balls Accept, some days your the pigeon, some days your the statue!
Post #267791 28th Jun 2014 1:19pm
if you look on topix it will show you how to fit sidesteps and there you'll see where the holes are.. ... - .- -.
Post #267796 28th Jun 2014 1:28pm
Googsy
Some dont though Stan. Mine certainly do but some on here dont necessarily have those screws Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #267803 28th Jun 2014 1:42pm
OE and all the aftermarket ones i've seen have the metal plates behind the panel and the flaps screw through that panel into the plate...
i had just mudflaps on mine and they were secured by screws that went in by the wheel arch.. ... - .- -.
Post #267804 28th Jun 2014 1:55pm
Googsy
Spot on i never had the steps so was focussed more on flaps Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #267825 28th Jun 2014 3:01pm
Ive never seen mud flaps fitted without the bolts that go through the lower plastic panel Rolling Eyes
Post #267833 28th Jun 2014 4:23pm
Boydonegood
Cheers all
Guess it's a case of either buying the 2 strips then £160 or a new set of sidesteps.
Will have a look around and see
Thanks anyway
Post #267834 28th Jun 2014 4:52pm
Googsy
You need to get out more then Laughing Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #267840 28th Jun 2014 5:59pm
mpirie
Oh, and by the way, you have two bolts going up through the horizontal brackets into the chassis and two pairs of two bolts for the vertical hangers that need to be loosened or removed to get each step off.
My mudflaps required the lower plastic panels to be drilled to hold the metal bracket and mudflap together, then replaced on the car, so removing the mudflaps would leave a hole.....which could be filled with body filler i guess and resprayed!
Oh, ffs, have i broken one of the cardinal sins of FF ownership? I'll get me coat Big Cry
Post #267920 29th Jun 2014 12:55am
Ner Ner Ner Ner Ner Ner
Post #267921 29th Jun 2014 12:59am
