![]() | Home > Maintenance & Mods (L322) > Side Step Repairs |
It all depends. It doesnt rust were you mention but sometimes after removing the flaps there will be a line where the mudflap sat against the panel. I reckon theres a good chance of rubbing this line with polish and it should remove most if not all of any evidence. You wont know until you try though as its dependent on how tight the flaps are against panel. Hope that makes sense. |
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 ![]() ![]() ![]() |
Cheers Fella!
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 ![]() ![]() ![]() |
Be interested to hear how that goes as I've been toying with the same idea. "On first name terms with my local Dealer......now."
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35609 ![]() ![]() |
if you remove the flaps you'll have two small holes showing in the lower panel... ... - .- -.
Oh really? |
if you look on topix it will show you how to fit sidesteps and there you'll see where the holes are.. ... - .- -.
Some dont though Stan. Mine certainly do but some on here dont necessarily have those screws |
OE and all the aftermarket ones i've seen have the metal plates behind the panel and the flaps screw through that panel into the plate...
Spot on i never had the steps so was focussed more on flaps |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Ive never seen mud flaps fitted without the bolts that go through the lower plastic panel |
Cheers all
You need to get out more then ![]() Gone Audi A5 2.7TDI Gone Discovery 3 HSE Gone Mercedes CLK Gone Range Rover 2.5 DSE |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 907 ![]() ![]() ![]() |
Oh, and by the way, you have two bolts going up through the horizontal brackets into the chassis and two pairs of two bolts for the vertical hangers that need to be loosened or removed to get each step off.
