I wouldn't worry to much about what the results should be as long as you're getting similar readings from all 8 cylinders. If there was a compression leak on one you'd probably see it being much lower then the other 7.
That's always what I've been told and it seems to have worked for me
David. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
