Home > Technical (L322) > 4.4 v8 compression test
Deanr_777
Range Rover 4.4 v8 petrol (BMW)
can someone tell me what numbers to expect from a cylinder compression test please? (Vehicle as above)
Thanks
Post #266641 21st Jun 2014 9:19pm
dhallworth
I wouldn't worry to much about what the results should be as long as you're getting similar readings from all 8 cylinders. If there was a compression leak on one you'd probably see it being much lower then the other 7.
That's always what I've been told and it seems to have worked for me Thumbs Up
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #266656 21st Jun 2014 11:21pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
^+1 Thumbs Up Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #266701 22nd Jun 2014 12:44pm
