Home > Wheels & Tyres > Tyre Blowout |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
The fact the wheel was too ho to touch sounds very odd, don't see why a sudden tyre failure would cause this. To my mind, it seems more likely the calliper was sticking and this heated the wheel and tyre up to the point of catastrophic failure.
11th Jun 2014 5:47am |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Dont know about TMPS as mine is disabled, their useless imo and checking tyres the old fashoned way is the only way.
11th Jun 2014 5:48am |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1513 |
As above, really hot would imply a stuck caliper.
11th Jun 2014 9:17am |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
+1 on checking the caliper. Glad no one was hurt and no lasting damage done to car. |
11th Jun 2014 9:54am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35329 |
the tpms should have detected the loss of pressure..because it didnt you might not have the system activated or you might not even have the tpms system..
11th Jun 2014 10:10am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3097 |
It definitely wasn't the caliper as after changing the wheel and keeping on going it was fine.
11th Jun 2014 12:54pm |
FWIW I had a screw in one of my rear tyres which caused it to slowly lose pressure - TPMS on my car flagged it 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
11th Jun 2014 1:23pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2265 |
Just an aside I put my summer tyres on in April and immediately the toms flagged a problem so yes I would have Landrover look at the system and pay for a replacement tyre
11th Jun 2014 8:07pm |
Well, it turns out that although our car has the TPMS valves fitted to it, the car doesn't actually have TPMS.
12th Jun 2014 1:15am |
Wow, seems the later the model of L322 the more stuff they seem to remove. I am surprised a 2012 AB spec car is not fitted with TPMS as standard. If you go back a few years the TPMS system was fitted as standard on the lower spec Vogues and Vogue SE's yet now its no longer fitted. |
12th Jun 2014 1:23am |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2567 |
Agreed, interesting system. Flat tyres can get very hot. |
12th Jun 2014 9:53am |
Tbh, we assumed our car had it as well as the 07 we had prior to this one had it.
12th Jun 2014 2:51pm |
I just find it bonkers that a modern car doesn't have some sort of TPMS on it |
12th Jun 2014 9:00pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6729 |
Or at least a TPMS system that actually works properly! Got - 2017 SDV8 Autobiography in Loire Blue
12th Jun 2014 9:05pm |
