![]() | Home > LPG > LPG and check engine light |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8491 ![]() ![]() ![]() |
LPG has a higher octane rating than petrol, so produces more power, it has a lower calorific value so you have to use more though... The check engine light has nothing to do with the quality of the LPG, it comes on for the reasons I stated earlier....
jambo27 Member Since: 03 Dec 2013 Location: Staffordshire Posts: 125 ![]() ![]() ![]() |
I have once had the same issue with my SC and it is due to go into the installer in the next few weeks for a check up and servic. I run a Prins system with valve lube.
Ningr Member Since: 20 Jun 2014 Location: Towcester Posts: 63 ![]() ![]() ![]() |
Haylands, thank you for the information. Finallay decided to treat her to a full LPG service from a local garage. Managed to ask all the questions i have gained on this topic and satisfied with their answers that they're not just after the money etc.
Ningr...
If it makes you feel better then fine but there is no need to do this... A few points to make.... modern unleaded petrol starts to lose it's octane rating after about three months so don't keep the petrol tank full all the time.... LPG first came out in Australia donkeys years ago, they used to run solely on LPG, it would start on it no bother so the petrol side never got used.... then, people ran out of LPG after driving on it for three years solely on LPG and the car spat it's dummy out about working on petrol and left them stranded, that's when the LPG makers started making them start on LPG and not switch over until a preset temp. The few minutes or so yours runs on petrol in the morning is plenty to keep the system working properly... Although modern LPG systems are injection systems they run differently to petrol, the vaporiser turns the liquid LPG into gas and then delivers it to the injectors, it meters this by means of an internal diaphragm, after a while the diaphragm wears and changes the settings, this is the main reason for getting them serviced.. after a few years it will get a hole in it and then the car will run terribly... then it needs a new diaphragm or vaporiser depending on cost/availability... There are also filters in the system which get clogged with a thick brown tar like substance called "heavy ends" which is within all LPG but varies a lot dependant on quality of the LPG (which usually has nothing to do with how expensive it is) My system which is a bit of a Heinz 57 with a Zavoli vaporiser and an AEB ECU runs great but took a lot of time to set up, the diaphragm holed earlier this year and it was cheaper to just buy another vaporiser for £47 than repair it. It was a 2009 unit so lasted 6 years but Zavoli are rather cheap and cheerful... Makes me grin and means mine get's into double figures MPG sometimes.... ![]() ![]() ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Barrie Springthorpe Member Since: 01 Dec 2015 Location: Lincolnshire Posts: 15 ![]() ![]() ![]() |
Hi, I read your article about LPG problems and I have the same at present. My L322 4.4 was running fine until it suddenly put the engine management light on, I thought it was a one off but no it has continued . I have had the car to a guy in Lincoln who has adjusted settings via his laptop but the fault return`s after a few miles and all I get from any garage that deal with LPG is how big is your wallet? it could be anything. I`ve changed 3 coils but no joy it still comes up with misfire, so if anybody knows a good LPG guy I`m more than happy to travel to him to get my RR put right, Barrie |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 340 ![]() ![]() ![]() |
Hi Barrie,
http://autogasyorkshire.co.uk/
Hi again, the LPG system is Tartaini , and was running fine and I am very happy with the mpg, cheers Barrie. |
Blair will sort it for you.... |
Hi again, how do I contact Blair and discuss my problem with him ? cheers Barrie |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
Phone and email on his website - but no problem - have cut and pasted below.
Hi, I rang Blair for a chat and booked my car in for a service , and although I`ve texted him and emailed his works to get directions and to confirm my booking I have had no reply, so he does not seem to be very reliable , is this normal because at this moment I`m not very impressed ,regards |
Weird, never had any problem with him... mind you haven't spoken to him myself for a while...
Hello Pete,and thanks for your reply, on the strength of the response from Blair and his company I don`t think I`ll risk an 2 hour plus drive to get them to service my car and I will look for someone a little more reliable, regards Barrie |
