Home > LPG > DIY LPG servivcing
jaipal2004
DIY LPG servivcing
Hi,
anybody done their own 'servicing' by means of reading off the LPG ECU and doing any changes themselves? If so - is it easy to do or shall I leave it to the experts? I do have basic experience of car tuning etc so appreciate the importance of getting values right etc
Post #262132 29th May 2014 3:30pm
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Me:
Etagas Tartarini
Zavoli
BRC
some OMVL 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #262207 29th May 2014 9:17pm
jaipal2004
Mine is an EMR one
Post #262210 29th May 2014 9:37pm
Sorry to go a bit off topic, but what's the deal with buying a LPG'd car without any certification? Is there anything obvious to look for, or is it best avoided? Got - 2017 SDV8 Autobiography in Loire Blue
Post #262211 29th May 2014 9:37pm
Jonno
Do you mean EMER?
This kit:
http://www.lpg-tech.co.uk/product.php?id_product=111 5.0 supercharged autobiography
Post #262215 29th May 2014 9:42pm
Re: DIY LPG servivcing
jaipal2004 wrote:
Hi,
If it's set up and running Ok and the emissions are alright then the only bits to service are filters in the solenoids, usually one at the tank and one at the vaporiser. After big miles the vaporiser can do with a clean out as you get deposits build up, need an overhaul kit that comes with a new diaphram etc
Only really need to plug in the ECU if you have faults or it's not runing OK, if it was set up well at install then it will follow the cars ECU and compensate all on it's own... Pete
Post #262217 29th May 2014 9:45pm
The question is, why hasn't it got one...
If it's been lost, not a problem as it will have been recorded on the LPGA website...
If it never had one then was it a DIY install and if it was does it comply with LPGA guidelines...
Get it checked by a registered installer, he will asses the install and can issue a certificate there and then if it's OK... Pete
Post #262218 29th May 2014 9:48pm
jaipal2004
Jonno..... Yeah sorry... I meant EMER Smile
Post #262224 29th May 2014 10:12pm
Checked the LPGA website, it's not recorded there, so I guess it was a DIY job. That then raises the question of wether it was fitted correctly of not. Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #262234 30th May 2014 12:01am
jaipal2004
Yeah I did the same.
The quality of the install send to suggest otherwise .... It looks to be a good job cosmetically :-/
I'll get the LPG service bods to check it and add to the database
Post #262245 30th May 2014 5:18am
Trossachsturbo
Scotland 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Same for me,check if the previous owner was on a private plate, then check that reg
Post #262409 31st May 2014 7:05am
steptoe
Your insurance company may need a certificate before they insure the vehicle. Also it may not be registered with the DVLA as a dual fuel vehicle. Which means you won't get the cheaper road tax. Very Happy
Post #262981 3rd Jun 2014 11:14am
jaipal2004
I did check and they've not requested one as yet.
And I thought all you got was a £10 reduction on the tax? If it's more I might get things done faster Very Happy
Post #262982 3rd Jun 2014 11:16am
Insurance companies only usually ask for the cert if you make a claim, if you haven't got one they won't pay for any LPG bits and may refuse the whole claim, not many ask for it when you take out the insurance.
RFL is only £10 cheaper so not much benefit there... Pete
Post #263020 3rd Jun 2014 7:27pm
steptoe
Any reduction no matter how small should be snatched from the government at the first opportunity as a matter of principal. Very Happy
Post #263026 3rd Jun 2014 7:48pm
