Home > Technical (L322) > TDV8 RR EGR Valve
Simon801
TDV8 RR EGR Valve
Hello all
I have a 2010 model RR Vogue SE which has just reported 'restricted performance' A quick code read from a mate suggests EGR valve B is the cause.
Which side is EGR Valve B?
Where on the engine is the EGR valve?
Does anyone have fitting instructions?
Many thanks
Simon
Post #261215 24th May 2014 4:05pm
you can download the WM from the wiki to help.. ... - .- -.
Post #261228 24th May 2014 5:15pm
Simon801
Fantastic thank you, exactly what I needed Smile
Post #261240 24th May 2014 5:44pm
Prop
Try to get it sorted asap, seems the EGR valves playing up on TDV8's can lead to some serious issues if ignored.
Post #261252 24th May 2014 6:33pm
mike & the mechanics
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
Bit of a pain to change so allow a few hours Thumbs Up Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #261257 24th May 2014 6:45pm
And they'll most likely suggest you change both. I'm sure I was quoted around £800 for both Got - 2017 SDV8 Autobiography in Loire Blue
Post #261281 24th May 2014 8:29pm
+1 for doing them both A, as they are both exposed and would be more work to do it all again for the other one in the coming months. & B, get it done ASAP! as your turbo runs the risk of over speeding which has destroyed a few turbos very soon after EGR replacement!
Post #261316 25th May 2014 12:50am
Simon801
Thanks for all the help & advice. Both EGR valves are now out and I shall be purchasing two tomorrow (if they have stock at the stealers) I stripped down the suspected faulty one and found that one of the metal 'fingers' thats work the mechanism that opens and closes the valve had snapped off and jammed up the workings, meaning the valve was stuck open. I have noticed that the side of the engine that has the faulty EGR, all the pipes are full of dry soot. The other side with the working EGR all the pipes have a slightly oily soot. Should I be worried about the difference? Should I be worried about the turbo on the oily side side?
Post #261546 26th May 2014 7:22pm
Simon801
Oh, and I have only driven the car about 5 miles since the 'restricted performance' warning came on the dash. I just limped home so hope I've not caused any further damage.
Post #261551 26th May 2014 7:41pm
