Home > Technical (L322) > TDV8 RR EGR Valve |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35279 |
you can download the WM from the wiki to help.. ... - .- -.
24th May 2014 5:15pm |
Simon801 Member Since: 30 Aug 2013 Location: Newark Posts: 10 |
Fantastic thank you, exactly what I needed |
24th May 2014 5:44pm |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
Try to get it sorted asap, seems the EGR valves playing up on TDV8's can lead to some serious issues if ignored. |
24th May 2014 6:33pm |
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 |
Bit of a pain to change so allow a few hours Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
24th May 2014 6:45pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
And they'll most likely suggest you change both. I'm sure I was quoted around £800 for both Got - 2017 SDV8 Autobiography in Loire Blue
24th May 2014 8:29pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
+1 for doing them both A, as they are both exposed and would be more work to do it all again for the other one in the coming months. & B, get it done ASAP! as your turbo runs the risk of over speeding which has destroyed a few turbos very soon after EGR replacement! |
25th May 2014 12:50am |
Thanks for all the help & advice. Both EGR valves are now out and I shall be purchasing two tomorrow (if they have stock at the stealers) I stripped down the suspected faulty one and found that one of the metal 'fingers' thats work the mechanism that opens and closes the valve had snapped off and jammed up the workings, meaning the valve was stuck open. I have noticed that the side of the engine that has the faulty EGR, all the pipes are full of dry soot. The other side with the working EGR all the pipes have a slightly oily soot. Should I be worried about the difference? Should I be worried about the turbo on the oily side side? |
26th May 2014 7:22pm |
Oh, and I have only driven the car about 5 miles since the 'restricted performance' warning came on the dash. I just limped home so hope I've not caused any further damage. |
26th May 2014 7:41pm |
