Home > General > how long does a gearbox last?
i think an oil change will probably be the first thing i do when i get my ffrr.......
Post #22708 19th Jul 2010 10:58am
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
I got my local auto specialist to do mine , flush, new filter and new fluid £140 all together. If I recall correctly I have around 75,000 miles at the minute.
Post #22719 19th Jul 2010 12:18pm
Fox
That's good. The filter alone from LR is about £90.
Post #22720 19th Jul 2010 12:28pm
silly question but is the gearbox oil separate to the engine?
Post #22732 19th Jul 2010 1:31pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Yes mate. It's different stuff/ not connected. It's supposed to be sealed for life I think but everyone on here seems to change theirs. Good advice given the life of the early gearbox. My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #22733 19th Jul 2010 1:36pm
thought so , thanks ...i see you've had few rr's then.
Post #22735 19th Jul 2010 1:53pm
dan_uk_1984
The trans oil on a Petrol ZF box needs to be replaced every 60,000 miles according to the gearbox manufacturer.
The trans oil on a Diesel GM box needs to be replaced every 50,000 miles according to the gearbox manufacturer.
If you stick to this and if the box hasn't been overheated then they should easily last to 250K, however LR has branded them Sealed for Life. Which only means for the life of the LR warranty.
If it changes fine when you buy it and you get a fluid and filter change done asap then you shouldn’t experience future problems with it. Be warned that overheating the oil by 1 degree cuts its effectiveness by 50% forever. So if you ever get trans overheat it's imperative that you do a change immediately.
Dan
Post #22738 19th Jul 2010 2:05pm
mike 1971
United Kingdom 2003 Range Rover HSE Td6 Zermatt Silver
Yep just had a recon box in mine cost £2600 including vodka and tonic Crying or Very sad
Post #22924 21st Jul 2010 11:02pm
Dan
great advice dan, thanks.
Post #22952 22nd Jul 2010 10:18am
Nappler
2003 Range Rover Vogue 4.4 V8 Java Black
Just had the gearbox oil in mine changed, be warned the Transmission fluid that the ZF box uses- Mobil ATF LT 71141, is expensive stuff,quoted £19.93 per litre inc VAT from LR dealer, found online for £102 for 12 litres delivered.
Post #23009 22nd Jul 2010 10:07pm
andyw
England 2002 Range Rover HSE 4.4 V8 Zermatt Silver
did you do t your self or did ou get a indie to do i am in surrey and my box could realy do with change
thanks 02 Range Rover HSE Zambezie silver 4.4
Post #23056 23rd Jul 2010 8:01pm
dan_uk_1984
I paid just under £150 inc labour, oil & filter from TES Transmissions, these guys buy the correct fluid by the barrell and not from LR so it won't cost them anywhere near that much.
Don't mess around doing it yourself for that price...
Post #23064 23rd Jul 2010 9:45pm
Nappler
thanks
I got an indie to do it,ex LR main dealer tech, very knowledgeable and a nice bloke too, don't know the rules on advertising on here but PM me if you want his number.
Post #23091 24th Jul 2010 2:45pm
