Home > Maintenance & Mods (L322) > Key won't turn in ignition |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 |
pretty sure it's the ecu on the steering column is knackered. comes as one complete unit 5.0 supercharged autobiography
19th May 2014 6:37pm |
Playsatan Member Since: 10 Feb 2013 Location: Glasgow Posts: 46 |
The transponder chip is needed to in the key, have you had it recut.
19th May 2014 6:38pm |
Duke Thrust Member Since: 07 Jun 2010 Location: Gloucestershire Posts: 59 |
In park and same result with both keys.
19th May 2014 6:44pm |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
Not sure if this is relevant. There is a linkage cable that causes issues with key if not operatiing correctly.
19th May 2014 6:49pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
this might help,
19th May 2014 6:54pm |
Thanks guys, the key's not stuck in the ignition, more that you can put it in, but not turn it.
19th May 2014 8:05pm |
On my 2007 (ignition in dash) I sometimes have it lift the key fob slightly to get it to turn ...just another thought before spending any money GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
19th May 2014 8:11pm |
After some experimentation this morning I've discovered that if I time it right, between the whur-whuuuuur noise I can get the key to turn with a bit of pressure - about 50% of the time.
20th May 2014 6:36am |
There are several linked ECU's that the key communicates with and every one has to return the correct response.
20th May 2014 7:37am |
