![]() | Home > Maintenance & Mods (L322) > Key won't turn in ignition |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
pretty sure it's the ecu on the steering column is knackered. comes as one complete unit |
Playsatan Member Since: 10 Feb 2013 Location: Glasgow Posts: 46 ![]() ![]() |
The transponder chip is needed to in the key, have you had it recut.
Duke Thrust Member Since: 07 Jun 2010 Location: Gloucestershire Posts: 59 ![]() ![]() ![]() |
In park and same result with both keys.
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Not sure if this is relevant. There is a linkage cable that causes issues with key if not operatiing correctly.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
this might help,
Thanks guys, the key's not stuck in the ignition, more that you can put it in, but not turn it.
On my 2007 (ignition in dash) I sometimes have it lift the key fob slightly to get it to turn ...just another thought before spending any money GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
After some experimentation this morning I've discovered that if I time it right, between the whur-whuuuuur noise I can get the key to turn with a bit of pressure - about 50% of the time.
There are several linked ECU's that the key communicates with and every one has to return the correct response.
