Home > In Car Electronics (L322) > 2005 Td6 MOST Harman Kardon sound issues
lordlucan
Hi guys.
My first post, so go easy!
I have a 2005 l322 Td6 with the most harman kardon 14 speaker system which I have owned for a few months now, following my father's passing. Having owned vws previously, I'm a bit unfamiliar and new to land rovers, but always been admirer.
I have a slight issue in that I have no sound from my wonderful stereo from either sat navigation, stereo or phone. It did work and then one day it all fizzled out when I was on the phone with sat nav on.
So far, I have checked the fuses, the fibre optics most ring is working as it should (no flashing light on head unit), no corrosion or moisture that I can see, reset system by disconnecting battery. I have been to my local dealer, fews in Charfield, who made a valiant effort to fix it (swapping working Nokia bit) and suggested that I start box swapping, starting with the amp. Managed to find an amp with exact serial number, still no joy.
I'm starting to become a bit frustrated and was wondering if there may be an expert in the Gloucestershire area who may be able to help/take the car to??
Thank you in advance.
Matt
Post #260039 18th May 2014 10:28am
