Home > In Car Electronics (L322) > Lights On Notice and Bong
Smegordead
United Kingdom 2002 Range Rover Vogue Td6 Buckingham Blue
Hoping someone can help with this really random issue.
I've been using NavCoder to switch on Follow Me Home (FMH) lighting and to ensure the right bulbs are being checked etc, these setting have all taken fine but and I've run into a couple of 'issues' that I'm hoping people here have some experience of.
a) Day Light Running (DRL) at any percentage does not seem to work at all
b) The 'Lights On' warning you'd normally get when you've left your lights on, ignition off and door open seems to have vanished.
Hope someone can help - I can live without DRL but the warning is really useful
Luke
2002 RR Vogue
Post #256308 26th Apr 2014 12:15pm
mjdronfield
I have the same on mine, can't get lights on to show. Just the follow me home lights when I finally turn the lights off.
I too used navcoder previously and set my fogs to the follow me home lights.
No knowledge of the percentage light and drl use, as I didn't try that.
I asked on the iidtool thread if the iidtool can enable it.
I'm also going to double check the cars manual so I can test without the follow me home being activated..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #256317 26th Apr 2014 12:50pm
Smegordead
I have turned off the DRL and the FMH but the lights on message didn't reappear
Did you get a response on the IIDtool thread?
Post #256320 26th Apr 2014 1:02pm
put it all back as it was before the adjustments of the CCF and see if the bongs return.. ... - .- -.
Post #256321 26th Apr 2014 1:03pm
mjdronfield
No conclusive response, but it was a bit off topic there to be honest.
Just checked my owners manual and it says you should still get the lights on message and the bong, even if fmh lights come on after. I don't get that either.
So, looks like we have the same issue. I've left my side lights on twice now by accident........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #256323 26th Apr 2014 1:06pm
Smegordead
I'm not 100% sure which Lamp Monitoring boxes where checked to start with - I've set it to all of them.
I have returned the DRL and FME settings to how they were before but no joy 2002 Range Rover Vogue
Post #256324 26th Apr 2014 1:06pm
mjdronfield
If I could remember how it was Stan, I'd be a happy man.
To be fair, I turned off every light test and warning when I was experimenting with led indicators, so I could have caused the issue myself....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #256326 26th Apr 2014 1:08pm
mjdronfield
Can I use the iidtool to set the light control module back to how it was, as I've not plugged the iidtool in since......like reflashing the unit, as oppose to setting it in any menu ?
Not sure it's in a menu in the iidtool........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #256327 26th Apr 2014 1:11pm
just wondering if the 'light check' function is linked to the 'lights left on' bong..
i have emailed patrick re this but i think he's very busy with the iidtool software upgrade.. ... - .- -.
Post #256329 26th Apr 2014 1:12pm
Smegordead
Is there anyone on here that has the lights on warning and bong working and has access to Navcoder that could check with lamp monitoring boxes are ticked for me?
I know it's a big ask but I've already spent days tinkering to get this warning back
Thanks in advance 2002 Range Rover Vogue
Post #256350 26th Apr 2014 2:25pm
mjdronfield
I've fired up navcoder on my laptop and cannot see an option specifically set for what we are after, so I'm not sure any of the check boxes will help us.
I'm wondering if it just gets reset when you do something else.
Must be a way of getting back on though, just need to know what and how to set in the ccf...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #256351 26th Apr 2014 2:32pm
Smegordead
So in NavCoder, on the menu under Code and LCM mine looks like the attached photo.
I'm just wondering what it should be as standard.....or as you said is there a way to completely reset it back to factory?
It's now the only thing that is different - I've removed follow me home and day light running 2002 Range Rover Vogue
Post #256352 26th Apr 2014 2:37pm
Smegordead
Just a quick update on this one for anyone interested - the latest firmware on the IIDTool (BT Version V3.00.00 B1660). Now has the lights on warning and bong option so this fixes that issue.
Yet another great update from the guys at GAP Diagnostics! 2002 Range Rover Vogue
Post #306936 21st Jan 2015 11:48pm
mjdronfield
Many thanks.
I read your reply and only now have I updated my IID Tool and been out and turned the Lights On warning and bong back on.
Pity I didn't do it last weekend before I left them on at work on Monday and had to be jump started by a Toyota Yaris.......... the rip taking will stop soon.... I hope Whistle
Thumbs Up to the chaps at GAP (again) 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #312782 15th Feb 2015 1:48pm
