![]() | Home > Maintenance & Mods (L322) > Restoring plastic |
jonlewis Member Since: 06 Nov 2012 Location: UK Posts: 308 ![]() ![]() |
Ground nut oil from supermarket works a treat 2011 Stornaway Grey 5.0SC Autobiography |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
Autoglym Plastic conditioner - fantastic stuff!! |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
That piece of trim is faded on mine too as it also was on my TD6. On that I used an old bottle of silicone based tyre gel (which I'd never really used on tyres) and it came up a treat.
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
Yep peanut butter works amazingly well. I have also seen people use heatguns (carefully) on the plastic and that also seems to bring it back to a fresher newer look too. Tom
See this similar previous post.
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 ![]() ![]() |
Erm is that for real about peanut butter and nut oil?
SAN's are easy..... tell me your woes......
On a serious note........
Peanut butter is sticky, but ground nut oil just soaks in really easily.
I'm going to try peanut butter to! Got to be done.
Gotta love that network latency. Presumably a blue site if using Metro ?
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
Yep, I've used peanut oil (must be the smooth one though) and does appear to work, I used it on the black trim at the base of the windscreen/around the windscreen wipers (and also on the A and D columns). Its like any other product though - doesn't last too long and you need to put it on regularly (in my experience) . Steve
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8562 ![]() ![]() ![]() |
If you want a permenant solution then use this
Mike.Boro Member Since: 09 Dec 2013 Location: Middlesbrough Posts: 44 ![]() ![]() ![]() |
