![]() | Home > eBay & Bargain Spots > Today Only : 44% off CTEK MXS 5 Battery Charger |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3858 ![]() ![]() ![]() |
I have standard towbar connections (twin sockets) and charging via the white one, although not recommended by C-tek works, just fine for me and of course has the advantage that you can leave the car locked up and if you like use the FBH before you disconnect it. |
The Ctek has to plug into the mains. |
Or you could go the way of some members and use one of the Ctek DC-DC systems and a big solar panel on the back shelf or a split charge system and fit a good sized second battery in the boot. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 952 ![]() ![]() ![]() |
king pleb have you a link to this kit as my car lives outside so this might be the only solution to me? |
Something like this
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
My CTEK arrived today - Thanks for the prompt! |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7851 ![]() ![]() ![]() |
I don't have an sc, but do have a genuine land rover battery in my td6.
Odds are that it's a standard battery and not AGM if it's the original one. Even a replacement is unlikely to be agm unless the owner that replaced it was feeling very flush! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
It's a standard OEM Land Rover 110AH with a Varta stamp on it as well - So "Normal" then. Thank you! 2006 4.2 SC
Same as my battery. I've not had an issue using the normal setting.
