Home > eBay & Bargain Spots > Today Only : 44% off CTEK MXS 5 Battery Charger
supershuttle
I have standard towbar connections (twin sockets) and charging via the white one, although not recommended by C-tek works, just fine for me and of course has the advantage that you can leave the car locked up and if you like use the FBH before you disconnect it. Thumbs Up Geoff
Post #253159 7th Apr 2014 9:27am
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
what does the other end plug into? i have no mains in my garage.... can you plug it in to a spare car battery for instance?
Post #253174 7th Apr 2014 12:03pm
The Ctek has to plug into the mains. Thumbs Up
If you have no mains available in your garage you could just plug a large 2nd battery into your car via the tow white socket to supplement the vehicle battery.
This simply increases the battery capacity of the battery(s) available to the car and so allows the batteries to "last" longer.
Post #253176 7th Apr 2014 12:09pm
Or you could go the way of some members and use one of the Ctek DC-DC systems and a big solar panel on the back shelf or a split charge system and fit a good sized second battery in the boot. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #253184 7th Apr 2014 12:38pm
andyleeds
king pleb have you a link to this kit as my car lives outside so this might be the only solution to me?
Post #253197 7th Apr 2014 2:03pm
Something like this
http://www.ctekchargers.co.uk/ctek-d250s.php
And possibly something like this if you want solar.
http://www.maplin.co.uk/p/13w-solar-briefcase-n00cx
But ideally a split charge system with battery in the rear is best long term.
http://www.ebay.co.uk/itm/T-MAX-SPLIT-CHAR...4d19eb64d9
+ this kind of battery
http://www.ebay.co.uk/itm/Optima-Red-Top-c...461da980ea
and then someone to install it.
The other option if your leaving your car a while is to just get the solar panel, fit an Accessory socket end to it, then just get the larger Bosch S5 020/ Varta I1 in the car as the main battery and your old one in the boot if it will fit Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #253201 7th Apr 2014 2:36pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
My CTEK arrived today - Thanks for the prompt! Thumbs Up
So, do you use "Normal" or "AGM"? I've read and re-read the manual and I'm not sure which my FFRR SC would have in it.
What's the opinion on this one? 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #253346 8th Apr 2014 2:40pm
mjdronfield
I don't have an sc, but do have a genuine land rover battery in my td6.
I use the normal setting.
The agm is however suitable when recharging from freezing type temperatures with a normal battery, so ctek told me on the phone.
I have the Mxs 7 unit, which does not have the auto temperature compensation function like this unit does.
Suppose you'll have to look on the internet and see if the battery you have is agm or not, and use the setting accordingly.
Is it a land rover battery ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #253350 8th Apr 2014 3:13pm
Odds are that it's a standard battery and not AGM if it's the original one. Even a replacement is unlikely to be agm unless the owner that replaced it was feeling very flush! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #253352 8th Apr 2014 3:40pm
SKOT
It's a standard OEM Land Rover 110AH with a Varta stamp on it as well - So "Normal" then. Thank you! 2006 4.2 SC
Post #253357 8th Apr 2014 4:58pm
mjdronfield
Same as my battery. I've not had an issue using the normal setting.
I've only needed to top it up so far, as the car doesn't go that far and I do watch TV in it.
Suppose I connect it once a month or so to make sure it's getting to full charge.
Just to be on the safe side...........
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #253358 8th Apr 2014 5:14pm
