![]() | Home > Maintenance & Mods (L322) > Tow bar armature. |
S33MAF Member Since: 04 Feb 2014 Location: WC Posts: 216 ![]() ![]() |
Looking to fit a tow bar to a 2011 FF, can anyone tell me if the armatures from other years fit?
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3196 ![]() ![]() |
From 2006 on, it changed due to the position of the flange. any after 2006 is ok. |
Don't see the point in having to weld an extra part on when the newer armatures are cheaper than the 2002-2005 ones anyway, but I see your point if you have already got an earlier version. |
I would have thought welding your own brackets on would be contrary to Towbar Type Approval Regulations ie
georgealexander Member Since: 10 Feb 2014 Location: Derbyshire Posts: 12 ![]() ![]() |
The brackets are only to locate the exhaust mounting and nothing to do with the integrity of the tow armature.The exhaust mounting changed from the TD6 to the TDV8 and hangs on the armature and that is the only difference between the two. They are both Westfalia tow brackets made for the Range Rover all the L322 chassis are the same.
@georgealexander |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
I got one off the bay of e a couple of months ago for £255, complete with ECU and wiring harness |
