Home > General (L405) > Electric tow bar
Electric tow bar
Has anyone else got this option who can tell me if mine is broken or I am not operating it properly. When I press the on/off switch in the boot (ignition off) I do not get a green light to say it is on. Is there anything special I should do, it doesn't seem so according to the manual.
Post #251952 1st Apr 2014 5:05pm
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
on/off? not sure what you mean , the boot switch retracts or brings the TB out ? Far to many gone...
Post #252120 2nd Apr 2014 6:13am
5.0
There are two switches. One to turn the tow bar mechanism on and another to swing it in or out. You are meant yo press one to turn it on and then the other to swing it out. When I press the on switch I do not get a green light to say it is on and the deploy switch does nothing.
Post #252132 2nd Apr 2014 7:24am
KeithG934
Mine seems to work fine as per handbook - tested it again this morning > on/off switch > green light > deploy/stow button. Not sure I'm getting what I would call 'warning tones' - more heavyweight motor sounds of movement and reassuring clunk when it's in place! Trailer electrics socket also there but haven't tested that wiring yet. Guess if you're not getting green light then refer to dealer?
Post #252155 2nd Apr 2014 9:37am
5.0
It seems as if it's broken. Back to the dealer again Mad
Post #252158 2nd Apr 2014 9:57am
tboner001
Has it ever worked ? if not has it been enabled by the dealer at PDI Far to many gone...
Post #252165 2nd Apr 2014 10:15am
5.0
No. This was the first time I tried it. If I have the ignition on I get a red LED showing on the on/off switch so there seems to be power to the switches but other than that nothing.
Post #252168 2nd Apr 2014 10:28am
thinking outside the box here, is the the engine running when you try cos it might need full voltage to operate.. ... - .- -.
Post #252170 2nd Apr 2014 10:43am
tboner001
should not need ignition
Red light never seen that before , almost like a fault warning that it is not stowed correctly or blocked ? Far to many gone...
Post #252173 2nd Apr 2014 10:48am
You can now buy a non electric towbar for the L405 which is about time, forcing owners to spend the £800 on build for the electric one was a bit of a con.
Even Paddocks sell the kit now.
http://www.paddockspares.com/tow-bracket-kit.html
http://www.paddockspares.com/towing-electrics-kit.html Discovery 4 HSE
Post #252180 2nd Apr 2014 11:05am
5.0
The red light is on the on/off switch if the engine is running or ignition is on. I assumed this was to tell you the tow bar would not deploy in these circumstances as the instructions say to do it with the ignition/engine off. Anyway booked into the dealer tomorrow so we shall see.
Post #252185 2nd Apr 2014 11:43am
5.0
Loose wiring was the issue Rolling Eyes . All fixed now.
Post #252431 3rd Apr 2014 2:29pm
n1cktdv8
I keep reading a few niggles on the L405. I know it could be expected on a new vehicle but not on a £90k car ? Is this where I put the car details and a bit about myself ?........
Post #252442 3rd Apr 2014 3:09pm
5.0
[quote="RRUK"]You can now buy a non electric towbar for the L405 which is about time, forcing owners to spend the £800 on build for the electric one was a bit of a con.
Well the factory fit one for the l322 was a £500 option so another £300 for electric operation is fair I think. It is very neat (invisible), a few seconds to deploy rather than a lot of messing about like the with the l322 one and it is also very cool for those who like gadgets - so not a con at all I think.
Post #252455 3rd Apr 2014 4:09pm
Nick Ground
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Indus Silver
I have the deployable towbar and it is worth every penny. Especially if you ask the cost of a retro-fit genuine one at he dealer.
Nick 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
gone 17 older variants of FFRR
Post #252463 3rd Apr 2014 4:41pm
