Home > In Car Electronics (L322) > TD6 Electronic problem?
lesmcm
South Africa 2003 Range Rover HSE Td6 Atacama Sand
I get trans failsafe displayed particularly when towing. The gearbox has been replaced twice also a new Gbox ECU fitted. When the alarm comes up there is no increase in engine revs, all gears are available and the fuel consumption stays constant. Checked all earth connections, new battery fitted, fuses checked and terminals cleaned. The alarm reading on my Hawkeye is P0740 excessive converter clutch slippage. But after 2 replacement gearboxes which were supplied by the most well known and respected gearbox company in South Africa I am convinced the fault lies elsewhere. I have checked the plug that goes into the gearbox electrically also the transfer motor. Any ideas or suggestions will be appreciated as I am now ata total loss as what to do.
2002 TD6
Post #249619 21st Mar 2014 1:55pm
is this any good?,
http://www.obd-codes.com/p0740 ... - .- -.
Post #249620 21st Mar 2014 2:08pm
lesmcm
Thanks Stan that is the most helpful article I have read. I had checked the cable and plug to the gearbox but will check it again. Unfortunately the Hawkeye reading is accompanied with "fault no longer present"or "intermittent fault" I will also check the positive feeds to the ECU. I tried to get the nearest agent to check with their test equipment but they could only do it in 3 weeks time and as they are 300kms away and would not quote a price to connect their equipment to it, I gave up.
Post #249754 22nd Mar 2014 7:13am
Have you checked your "hi/low" transfer box motor is working? This also brings up the same dash message sir... Thumbs Up
Post #249791 22nd Mar 2014 11:44am
lesmcm
Hi
Yes checked and used occasionally. Do you think this problem has the potential to do any damage we have done about 10k since the new gearbox was fitted and it has only occurred once when I am not towing. It is so dammed intermittent when towing may occur after 20kms or 200kms and I can find no common factor when it occurs.
Post #249828 22nd Mar 2014 2:54pm
Yes i think it will have the potential to do damage... Best getting it checked to be sure Thumbs Up
Post #249832 22nd Mar 2014 3:07pm
lesmcm
Hi
Yes I would take it to the nearest agent, a round trip of 6/700kms, plus having to stay overnight for 2 nights, if I felt I had any confidence in them and they would give some indication of price. The alternative is to go to Cape Town a round trip of 1400kms at least one agent there is helpful. This is why I am asking for any ideas, the only thing I can see at the moment is possibly the gearbox ecu cable has been damaged in some way. I think this gives some idea of the problem of living so far from "civilization" and owning a complicated vehicle. Any other suggestions will be appreciated.
Post #250390 25th Mar 2014 9:02am
Riverstick
Ireland 2015 Range Rover Autobiography SDV8 Santorini Black
Re: TD6 Electronic problem?
2002 TD6
Sounds like your torque converter is on the way out. The transmissions rarely give trouble in their own right, it normally is the debris from the torque converter breaking up which clogs the transmission valve chest and causes all sorts of grief.
The electronics are alerting you to the fact the torque is slipping under load and overheating the transmission oil in the process.
Drop you transmission and fit one of these...it will tow forever with very few problems afterwards
http://www.roadblaster.com.au/pages/RANGE%...L40-E.html 2008 Range Rover TDV8 435,000kms
2015 Range Rover L405 SDV8 Autobiography
2008 Ford Focus1.6 tdci Titanium DPF deleted
Post #254161 13th Apr 2014 8:27am
