![]() | Home > Maintenance & Mods (L322) > rear reflector lights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
the white ones looked pretty bright in the daylight so i can imagine how better they would look in the dark.. ... - .- -.
would reflectors be needed for 'mot' tests in your part of the world Eugene? ... - .- -.
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Eugene...How about reusing the originals?.
good idea Paul.... |
That's a good one guys! Don't have the towbar but do have the mudflaps. Otherwise I may make a little bracket to fix them on the inside of the bumper. But will use the originals indeed. Also planning to use the red leds attached to the brake lights that won't hurt here with the way people drive here! The more brake lights the better. You also see a lot of flashing 4th brake lights here plus heaps of extra leds not planning to do thst though the FFRR should remain standard as much as possible! Do need to switch the DRLs on. MY 2010 5.0 SC Galway green and sand interior!!
by coincidence i've looking at the units that make the brake light flash when braking..
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
Very Cheap Stan |
its maybe to cheap, but what about this one,
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7860 ![]() ![]() ![]() |
I would like to have rear brake light flashing strobes that I can switch on anytime in case I have to stop in a dodgy area, not like Stoke on Trent, I mean like the hard shoulder.
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
"not like Stoke on Trent,"
My SWMBO comes from newcastle under Lyme....
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16312 ![]() ![]() ![]() |
Opinions on these on a Stornoway Grey...not sure myself |
