Home > Maintenance & Mods (L322) > Added some DRLs
Stocky
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Fuji White
Added some DRLs
I've wanted to fit DRLs for a number of years as I feel they are a safety benefit. So when I got the latest FF, about a year ago, I started to look into doing it on this one. Followed the various threads re halo lights etc. but didn't really want to follow that option. I can't justify an IID tool at this time, and that only seems to allow the angel lights with reduced xenons in the middle. I would love just the angel lights, but much brighter, but that doesn't appear to be an option. I also wanted to keep my fog lights.
So I got a set of Osram DRLs from amazon. A little expensive yes, but includes everything you need and are definately OEM quality. The control unit does all the work just connecting to the battery (yes, direct to battery to know when engine on) and the sidelight wire. So very simple to fit. I have fitted them to the front tow eye cover and used Super Seal connectors for easy removal when towed. That way, if I want to put it back to factory for resale later, I just need to replace with a new cover.
Took couple of hours to do, mainly down to routing the cables. The control unit works well and dims the brightness when sidelights etc are on, so they don't dazzle in poor light.
Anyway to the pics...
Close up in place
Before...Just side lights/angel eyes
After...DRLs only
Side lights and dimmed DRLs
Dipped beam and dimmed DRLs
Just thought I'd share it with you all. I know they won't be to many peoples taste but I think they achieve what I wanted.
Post #245229 27th Feb 2014 12:31pm
looks good Ian, did you consider using the fogs with leds in them as drls?
Post #245230 27th Feb 2014 12:35pm
Philip
Re: Added some DRLs
Just turn your lights on.
Post #245235 27th Feb 2014 12:45pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Thumbs Up Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #245238 27th Feb 2014 12:47pm
verydisco
Nein, sorry.
As a matter or fact, you already have DLR in your headlights - that is enough.
I would have kept the £ towards a useful IID tool.
to each his own. Wink l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #245252 27th Feb 2014 1:12pm
ignore them Ian they're just jealous.. Laughing
btw ,have you a link to the drl switch?
Post #245256 27th Feb 2014 1:15pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Do you have sbphoto where you connected to the battery. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #245259 27th Feb 2014 1:20pm
J90
France 2006 Range Rover Vogue Td6 Java Black
That's a nice mod particularly if like me you have a pre 2010 RR. Driving around in daylight with dipped beam on can look a bit flash and sidelights can be a little too dim at times. DRL's certainly have their use.
As per rej and stan, do you have any additional pics or info.
Ta Travelling around in circles again.
Post #245264 27th Feb 2014 1:34pm
Philip
As opposed to gluing some fairly lights to the front?
Post #245270 27th Feb 2014 1:42pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
From the AA web site:
'Retrofitted daytime running lights should be installed so that they come on with the engine and go off when other lights are turned on.'
Post #245275 27th Feb 2014 1:48pm
paulmoran2
I got this little beauty off the bay yesterday / arrived today, so will be wiring it up to the fogs (that i've fitted LED units in to) over the weekend. £10 for the DRL switch and £45 for the LED fogs C/O Powerful UK. Wiring diagram also for you teckies.
Seems you can set up dimming of the DRL's to side, head or both activation.
Post #245284 27th Feb 2014 2:21pm
Stocky
I'll get some more pics on tomorrow morning if poss.
Stan, I didn't want to loose my fogs.
PaulT, Vosa allow if dimmed in conjunction with other lights. Many factory fit ones do this as you can see on road.
Post #245304 27th Feb 2014 2:52pm
Stocky
Some more pics as requested
Kit of bits
ECU in position, double sided adhesive pad on suspension mounting area just ahead of battery compartment.
Battery connections, just two small cables onto +ve terminal. Red - Power Orange - Sensing for engine running (Some waves across battery apparently, can't find the instructions to get the real wording!)
[/s]
Post #245807 2nd Mar 2014 3:42pm
J90
Thanks Stocky. Very useful pics. Ta. Travelling around in circles again.
Post #245833 2nd Mar 2014 5:34pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
@paulmoran, lovely pencil, but what is that switchthing alongside the pencil
Laughing
Post #245836 2nd Mar 2014 5:44pm
