Home > In Car Electronics (L322) > ECU problem |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8232 |
What tools are you trying?? I've got two generic OBD readers and neither want to talk to the FF, my IID will chat all day long to it though...!!! Pete
10th Feb 2016 4:34pm |
Yep, they should work... I take it you have had a good look at the connections in the port as they can get damaged, it's usually pretty easy to spot the one that looks different, you do have to be a contortionist to see well though.... It will work with a meter end into it but not work with the fine pins on the OBD plug to the tool Pete
10th Feb 2016 7:29pm |
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 |
I took the socket out and inspected all connections, and they are fine.
10th Feb 2016 8:07pm |
An update from me after some investigation.
18th Feb 2016 4:49pm |
