Home > Technical (L322) > Door Mirror Glass
Renegade2
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Door Mirror Glass
The drivers door mirror glass had gone a horrible dark yellow colour which i was told was the Electrochrmatic breaking down, so ordered new glass which arrived today.
Any one know how the old one comes of? looking at the replacement it seems to twist but there are also some clips on there. Dont want to force the old one and break something else so any assitance would be appreciated.
Thanks
Post #102483 19th Jan 2012 6:29pm
L322Pilot
England 2002 Range Rover Vogue 4.4 V8 Buckingham Blue
Insert 2 flat blades such as screw drivers under the mirror and gently prize it upwards, it will pop out of the retaining
clips. If you look at the back of your new mirror you will be able to visualise how it fits. I paid £185 for a new mirror
how much was yours.
Post #102489 19th Jan 2012 7:02pm
T24RES
I paid £100 from the bay of e Thumbs Up
Post #102490 19th Jan 2012 7:14pm
Renegade2
Thanks for the info, i was quoted £158 form main dealer so i tried partsgateway where i was quoted £55 for CRD500280. Piad for it being december but not turned up so i put in a complaint and had a refund of the £55 plus they paid and sent a brand new from a main dealer and arrived today!!!!!!!! Result!
I did see the same part number on Brit parts for £72!!
Post #102494 19th Jan 2012 7:35pm
Renegade2
L322Pilot
Thankyou ever so much for the advice, job done and all ok. Would have been lost without that.
Cheers
Post #102532 19th Jan 2012 11:02pm
Googsy
14 posts and hes showing off already . Youll be getting a home visit from Scarey next Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #102545 20th Jan 2012 1:10am
.....only to thank mr pilot for his contribution.. Thumbs Up ... - .- -.
Post #102553 20th Jan 2012 8:26am
L322Pilot
Does the £55 mirror have the chromatic function which reduces glare when a car with fancy headlights is behind you, like maybe a FFRR?
Post #102619 20th Jan 2012 1:54pm
Short answer no,
Long answer chromatic glass is a bronzy colour and about £140ish and standard heated glass is blueish and about £80 . 2008 MY Supercharged
Post #102675 20th Jan 2012 4:59pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Can you fit the electrochromatic mirror glass in place of the heated glass? (the reason I ask is that Sunday night I was passing a row of parked cars. There was a gap ahead of me so that I could pull in to let the boy racer coming towards me pass, but he decided he'd floor his accelerator and come straight at me, not giving me enough time to reach the gap to let him pass. End result, I had to get right over towards the left to avoid him hitting me, and my passenger door mirror glass is now toast and will need to be replaced). The (now shattered) glass I have is the heated variety, but I wouldn't mind fitting the dimming version if I can and it will work - don't know if the mirror body is different on the dimming version - if it is, I don't want to go down the route of replacing the entire mirror, I'll just get a new heated glass.
Grateful for any advice. Big Cry Big Cry
Post #243275 18th Feb 2014 5:10am
Ray, it would help if you filled in your car profile so when you ask questions people can give the correct advise for your model... Thumbs Up
Post #243285 18th Feb 2014 8:06am
Full Fat Ray
Sorry Craig Embarassed When I set up the account I hadn't yet got my full fat, and i am still new to this wonderful system (bit of a dinasaur I suppose) Thumbs Up
Post #243307 18th Feb 2014 10:10am
Full Fat Ray
Can anyone give me an answer on this please as i need to get a new mirror glass sooner rather than later - being without the passenger side mirror is a pain in the Censored !! 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #243745 20th Feb 2014 4:26am
T24RES
The chromatic mirrors work in conjunction with the chromatic rear view mirror, this would require a module/ecu for that feature. The fitting of a single chromatic mirror won't activate an option that isn't fitted. Ian
Post #243756 20th Feb 2014 7:37am
Full Fat Ray
I have a photochromatic rear view mirror and power fold exterior mirrors fitted - looking in a 2004 price list a friend has lent me, the photochromatic exterior mirrors can only be fitted when the photochromatic rear view and powerfold exterior mirrors are specified, we have these but I am assuming there would need to be some kind of a feed to the exterior mirrors (over and above the feed to the heating elements, which I suspect is only 'live' for a short time when the temperature sensor can tell that it's cold outside?) 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #243779 20th Feb 2014 10:11am
