Home > Technical (L322) > Tdv8 timing tool l322
Petr
2007 Range Rover Vogue SE TDV8 Java Black
Hi guys
I wonder if someone can help.
I have a tdv8 l322 2007.
A few months ago my car broke down on the motorway, engine ceased.after taking it to my local garage found out the left hand turbo failed.
After stripping the engine down we found out that the turbo oil seal leaked which sucked out the oil from the engine and throw it into the top end of the engine which resulted in having a cracked piston and and bend piston arm.
After great effort finally found a new piston and piston arm. My mechanic had to rebuild the top part of the engine which is now done and back in the car.
After all the it seems we have a MAJOR problem in getting hold of a TDV8 TIMING TOOL. to line the engine up.
We tried land rover they do not sell it, as they only have it for there own purposes.
Does anyone know of where I can get one/borrow one.
Obviously I will pay for the rental of one.
Look forward to your help guys
Cheers!
Post #242966 16th Feb 2014 3:14pm
if it is such a specialist tool i would think you'd have a hard time getting someone to rent it out to you...good luck on your search..
Post #242968 16th Feb 2014 3:43pm
How friendly are you with your local Main Agent service manager? Usually a large deposit helps Thumbs Up
Post #242994 16th Feb 2014 5:43pm
fisha
You may need to source from the Far East .... I don't know what the real one looks like, but this looks like the type of locking you would have for a v8 setup....
http://www.alibaba.com/product-gs/13550008..._sold.html
Min order qty is 1 , so you might be able to get just the one sent over V8 or else ...
Post #243108 17th Feb 2014 9:07am
