Home > Technical (L322) > Charging rate down to 13.8v |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
What is going on?
14th Feb 2014 5:39pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7950 |
How old is the alternator ?
14th Feb 2014 5:46pm |
New alternator, nothing's been touched since it was fitted. Ian |
14th Feb 2014 5:49pm |
I did. That is the voltage with everything off Ian |
14th Feb 2014 6:10pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
That's a nightmare. Maybe the voltage regulator is faulty? Present :2008 TDV8 HSE
14th Feb 2014 6:27pm |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
I might be wrong, but if your battery has a good charge then 13.8 should be what the alternator/charging system deems as sufficient, it maybe that the alternator will output more when the battery is not as well charged.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
^+1 The output voltage of the alternator varies depending on electrical load and state of battery charge level.
14th Feb 2014 7:24pm |
paranoia is rife at the moment. I'll keep an eye on it. Ian |
14th Feb 2014 7:29pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Ian, the guys above are quite correct... Finally it would appear the alternator & battery are in sync |
14th Feb 2014 7:38pm |
Lets hope so Craig Ian |
14th Feb 2014 8:33pm |
drivesafe Member Since: 19 Mar 2008 Location: Gold Coast Posts: 126 |
Hi Ian and when did you actually measure the voltage.
20th Feb 2014 1:45pm |
It's been parked since Sunday, first turn of the key and no disco or bongs. Let's hope that's the back of it Ian |
21st Feb 2014 2:13pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8625 |
Sounds promising! There is nothing that can't be fixed with a hammer😜😜
21st Feb 2014 5:43pm |
Seems to be regulating itself properly, had a check of the voltage today and peaked at 14.9v before settling down Ian |
24th Feb 2014 2:40pm |
