Home > Technical (L322) > Charging rate down to 13.8v
T24RES
What is going on?
A can of 4* is looking mighty appealing at the moment. Ian
Post #242693 14th Feb 2014 6:39pm
How old is the alternator ?
Connections all clean and tight ?
Post #242694 14th Feb 2014 6:46pm
T24RES
New alternator, nothing's been touched since it was fitted. Ian
Post #242695 14th Feb 2014 6:49pm
Did you fit it ? If not then take it back to whoever did
Loose belt or dodgy connection ?
What's the battery voltage with everything off ?
Post #242697 14th Feb 2014 6:55pm
T24RES
I did. That is the voltage with everything off Sad Ian
Post #242701 14th Feb 2014 7:10pm
Googsy
That's a nightmare. Maybe the voltage regulator is faulty? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #242704 14th Feb 2014 7:27pm
Prop
I might be wrong, but if your battery has a good charge then 13.8 should be what the alternator/charging system deems as sufficient, it maybe that the alternator will output more when the battery is not as well charged.
When I have measured mine it very often goes to over 14.5 volts for a few minutes but then drops down to 13.8v.
Post #242705 14th Feb 2014 7:27pm
^+1 The output voltage of the alternator varies depending on electrical load and state of battery charge level.
I'd be inclined not to worry too much for a few days and see how it goes.
Mine frequently drops below 14V but the battery is still fully charged.
Post #242709 14th Feb 2014 8:24pm
T24RES
Thumbs Up paranoia is rife at the moment. I'll keep an eye on it. Ian
Post #242711 14th Feb 2014 8:29pm
Ian, the guys above are quite correct... Finally it would appear the alternator & battery are in sync Whistle Thumbs Up
Post #242718 14th Feb 2014 8:38pm
T24RES
Lets hope so Craig Thumbs Up Ian
Post #242735 14th Feb 2014 9:33pm
drivesafe
Australia 2007 Range Rover Vogue TDV8 Stornoway Grey
Hi Ian and when did you actually measure the voltage.
If you have been driving for a while, as others have mentioned above, 13.8v is fine.
But even if your battery is fully charged, you should get a short period of 14+v shortly ( about 30 seconds ) after you start your motor. 2007 TDV8 Lux
Post #243829 20th Feb 2014 2:45pm
T24RES
It's been parked since Sunday, first turn of the key and no disco or bongs. Let's hope that's the back of it Thumbs Up Ian
Post #244042 21st Feb 2014 3:13pm
Sounds promising! There is nothing that can't be fixed with a hammer😜😜
Post #244096 21st Feb 2014 6:43pm
T24RES
Fixed
Seems to be regulating itself properly, had a check of the voltage today and peaked at 14.9v before settling down Thumbs Up Ian
Post #244655 24th Feb 2014 3:40pm
