Home > In Car Electronics (L322) > For f**k's sake |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
I have some matches and petrol
10th Feb 2014 4:44pm |
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 |
Already got the petrol thanks gone fishin' |
10th Feb 2014 4:47pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35356 |
cant remember if you've replaced the battery or not but these could be characteristics of a low voltage battery.. |
10th Feb 2014 5:08pm |
Friggin same here parked the POS up yesterday went out today at 4.20 to go an errand , whirr whirr whirr , friggin battery dead ....
10th Feb 2014 6:01pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7812 |
I stick mine on trickle charge about every 3 or 4 weeks, as I don't travel far each day and watch tv in it for an hour a day.
10th Feb 2014 6:24pm |
Battery seems o.k, fired up lovely gone fishin' |
10th Feb 2014 6:36pm |
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 |
Check for water in the left hand rear compartment as this was the same problem in my daughters RR. Shorted out plug in the radio module.
10th Feb 2014 7:53pm |
Had just left the car at the side of the house since earlier , neighbour has just chapped the door to tell me all my rear lights are flashing on and off ..... |
10th Feb 2014 9:37pm |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
Identical problems happened to my car. The next day everything worked fine, couple days later same problem. This went on over a couple of weeks. It was the LCM (Light control monitor). Bought a used one from a breakers £120. |
11th Feb 2014 10:59am |
Ah well RAC called out earlier , spent about 40 mins with the car checked battery and such finally came to the conclusion that I have a 2.5 amp battery drain somewhere , so looks like I will have to get it booked into the stealers , this should be fun .... |
11th Feb 2014 2:58pm |
pulled out the lear amp in the back every thing works o.k lights etc but not checked the sat nav,radio,cd as the amp is out. I will check the connections on the pins later, "touch wood"
11th Feb 2014 7:43pm |
marcoos_1 Member Since: 25 Oct 2012 Location: Glasgow Posts: 138 |
I had a Bluetooth module go down with water in the rear left apparently.
11th Feb 2014 9:40pm |
common problem, search ''water shedder'' |
11th Feb 2014 10:01pm |
