Home > In Car Electronics (L322) > For f**k's sake
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
For f**k's sake
Parked up friday, didn't touch it all weekend ,when i started it up no screen, no radio no indicators (working outside but not on the dash), no reversing lights indicators don't flash when you lock/unlock any idea's before i burn it Confused gone fishin'
Post #241700 10th Feb 2014 5:38pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
I have some matches and petrol Rolling with laughter Rolling with laughter
Sorry no help at all I know! hope you get it sorted If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #241701 10th Feb 2014 5:44pm
andyboy
Already got the petrol thanks gone fishin'
Post #241704 10th Feb 2014 5:47pm
cant remember if you've replaced the battery or not but these could be characteristics of a low voltage battery..
Post #241709 10th Feb 2014 6:08pm
Friggin same here parked the POS up yesterday went out today at 4.20 to go an errand , whirr whirr whirr , friggin battery dead ....
Nothing left on , battery is only about 6 months old ... Poxy FF Censored
Post #241723 10th Feb 2014 7:01pm
mjdronfield
I stick mine on trickle charge about every 3 or 4 weeks, as I don't travel far each day and watch tv in it for an hour a day.
No issue so far...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #241730 10th Feb 2014 7:24pm
andyboy
Battery seems o.k, fired up lovely gone fishin'
Post #241731 10th Feb 2014 7:36pm
SGW
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
Check for water in the left hand rear compartment as this was the same problem in my daughters RR. Shorted out plug in the radio module.
Stewart
Post #241747 10th Feb 2014 8:53pm
Had just left the car at the side of the house since earlier , neighbour has just chapped the door to tell me all my rear lights are flashing on and off ..... Rolling Eyes Rolling Eyes
Post #241798 10th Feb 2014 10:37pm
steptoe
Re: For f**k's sake
Identical problems happened to my car. The next day everything worked fine, couple days later same problem. This went on over a couple of weeks.
It was the LCM (Light control monitor). Bought a used one from a breakers £120.
Post #241896 11th Feb 2014 11:59am
Ah well RAC called out earlier , spent about 40 mins with the car checked battery and such finally came to the conclusion that I have a 2.5 amp battery drain somewhere , so looks like I will have to get it booked into the stealers , this should be fun .... Rolling Eyes Rolling Eyes
Post #241953 11th Feb 2014 3:58pm
andyboy
pulled out the lear amp in the back every thing works o.k lights etc but not checked the sat nav,radio,cd as the amp is out. I will check the connections on the pins later, "touch wood"
there was a bit of water in the back i thought i'd sorted that out gone fishin'
Post #242037 11th Feb 2014 8:43pm
marcoos_1
Scotland 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I had a Bluetooth module go down with water in the rear left apparently.
Is there not any way to protect this or fix the design fault that lets water or moisture in. I live in Scotland for F**k sake....I'll have no modules left by the end of the year if I don't do something to protect the new FF.
Anyone any ideas?
Post #242074 11th Feb 2014 10:40pm
common problem, search ''water shedder''
Post #242085 11th Feb 2014 11:01pm
