![]() | Home > Maintenance & Mods (L322) > Tools everyone should know about (please add) |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
4 post ramp, everyone should have one |
B9er Member Since: 10 Dec 2012 Location: Larne Posts: 191 ![]() ![]() ![]() |
An original SuperTool, countless times it has helped fixed things from Audi UR Quattros to Zips, when access to normal tools has not been possible |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
WD40, and when that doesn't work - silicon sealant. |
Duck tape wrapped around the business end of the wheel brace... stops the alloys getting chipped and scratched when manually loosening/ tightening wheel nuts. |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
Home made large T bar, made from 2 pieces of scaffolding pipe welded into a T.
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
FullFatRR Forum on ur phone |
The proper use for Duct Tape ![]() ![]() ![]() ![]() |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Quality head torch. |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Along with the other fine suggestions I find these very handy.
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 187 ![]() ![]() ![]() |
be carefull with those toffee wheels if you get to heavy they will mark the lacquer/paint |
Mr Muscle... wheels and other uses. Just type 'Mr Muscle' in the forum search engine |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16208 ![]() ![]() ![]() |
You need to be careful on cheaper quality re-paint's too... |
S33MAF Member Since: 04 Feb 2014 Location: WC Posts: 216 ![]() ![]() |
Metric adjustable spanner. |
Forget the adjustable - If you want one emergency tool for undoing nuts and bolts, you need one of these.
