Home > Technical (L322) > Fault findings !!!
Steverr
United Kingdom 2003 Range Rover Vogue Td6 Zermatt Silver
Fault findings !!!
Hi, is there anyone who know what these faults are from my IID tool. They keep retuning
ECM engine
0404 unknown
3505
Hid right headlight
2a ignition voltage 7.5 volts
Hid left headlight
Ip
Bd -ebv function fault received from abs ecu
Bf instrument pack checksum incorrectfault
C-ecu EEPROM
8e-right side marker defective
8f Left side marker
0094- unknown
0095- unknown
Pats - anti theft
23 key 2 random code tolerance increased
33 key 3 random code tolerance increased
Thumbs Up for any help
Steve
Post #237727 28th Jan 2014 4:03pm
michele5041
United Kingdom 2003 Range Rover HSE 4.4 V8 Baltic Blue
I also have the Headlamp Error codes and L & rhs markers defective.
Post #237746 28th Jan 2014 6:51pm
From memory and in exchange from GAP and if I remember correctly you can ignore most of the errors. (If I get the chance will dig out backup info on this...)
I get most of these back from my IID if I do a full scan. Clear them and they come back Wink
The side marker ones probably relate to LEDs ?
The ones I haven't seen before are for the headlghts..... .
Post #237793 28th Jan 2014 9:30pm
Steverr
Thumbs Up cheers joe you ledge Very Happy
Post #237805 28th Jan 2014 9:59pm
rathbranV8
Ireland 2002 Range Rover SE 4.4 V8 Oslo Blue
I also have the side marker light messages,clear them and they constantly come back
Post #237826 28th Jan 2014 11:31pm
I wasn't quite accurate about not needing to worry about all of them!
Direct from Patrick at GAP:
Quote:
“3505 Unknown (Engine)”
Glow plug relay failure - glow relay defective. This one should be investigated if your engine is hard to start when cold. ((oh - this might answer my hard to start thread, although it has taken a while for it to surface)) The relay is in the big black box of goodies in the engine bay - see RAVE
“0404 Unknown (Engine)“
Extended fault path exhaust gas recirculation governor deviation - negative deviation. Are your EGR blanked?
"BD EBV Function Fault Received from ABS ECU"
We’ve seen this fault on other vehicles also. It may disappear after a while (when a clear fault is done of course). Check your ABS ECU’s fault to see if there is something in there, if not, leave it alone.
“BF Instrument Pack Checksum Incorrect (?)”
This error will not affect the functioning of the IPC and can be left alone. Did you check the fault before and it wasn’t there or did it appear after a diagnostic session with a T4? This can sometimes happen when a configuration is changed inside the IPC. To solve this, you can change a configuration (for example, Park Heating) in the IPC Car Config function. Come back to us with the results if you decide to try.
"8E and 8F Right/left Side Marker defective"
Your LED’s are causing these faults. The LCM thinks the lights are burned out since the current draw is significantly lower than with incandescent lights.
"23-Key 2 random code tolerance increased"
We’ve seen many RR with this errors including our 2005, nothing to worry about.
If you send an email to GAP, they can respond on the others Thumbs Up .
Post #237828 28th Jan 2014 11:37pm
