Home > Maintenance & Mods (L322) > Bonnet catch not holding
jumbocar
2004 Range Rover Autobiography 4.4 V8 Zambezi Silver
Hi
The passenger side bonnet catch has stopped doing its job, the driver side locks when the bonnet is closed but the passenger side does not lock shut. When driving a high speed you can see the bonnet lifting on the passenger side- very unnerving!
Can anybody help with part numbers so I can order whatevers required to get the bonnet to lock shut again?
I think the catch has rusted up so its not holding anymore...
Thanks
Post #237430 27th Jan 2014 11:20am
have a look on microcat or pm ducky dan....
Post #237431 27th Jan 2014 11:30am
Mr Tee
Grease up the locating hole on the slam panel in the meantime, I lashed some on mine , free it off with a big screwdriver to get it moving again, loads of road crap gathers there and seizes up the mechanism, almost shat myself when the bonnet lifted going down a motorway one day....
Post #237432 27th Jan 2014 11:50am
jumbocar
Nearly shat yourself?
I beleive that, I pretty much wet myself seeing the bonnet lift while I was on the motorway this weekend. Need to get this sorted asap...
Post #237434 27th Jan 2014 12:18pm
The catch is made of plastic and metal, held together with 2 bent over tabs and a rivet. Unbent the tabs and use a Dremel type tool to remove the rivet. Once the catch is opened the problem can easily seen, rust on the top plate and crap inside the plastic causing it to jam. I wire brushed the top and bottom plates and gave them a coat of paint, cleaned out the plastic parts and reassembled with a light coating of grease, the rivet was not able to be reused so I fitted a round head bolt and a lock-nut instead and hammered the bottom of the bolt once assembled to ensure it would not work loose. You have to make sure the top of the bolt is lower than the metal plate or it will foul on the slam-panel.
Post #237436 27th Jan 2014 12:32pm
