Home > Maintenance & Mods (L322) > Pictured - Is it the Wheel Bearing? |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
That sir is yer driveshaft |
26th Jan 2014 9:48am |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
When you are driving and you hear the "bearing" noise does the noise get quieter, noisier or stay the same when you turn left or right? A faulty bearing will sound different under load, noticeably around corners.. Previously..
26th Jan 2014 9:56am |
Can i make the suggestion you change tyres about first! As that is far cheaper then a new hub unit (wheel bearing not available separately)
26th Jan 2014 9:57am |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 |
26th Jan 2014 10:10am |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
I would try rotating them but it depends on what tyres they are.
26th Jan 2014 10:12am |
Jay, the "sawblade effect" seams to be a phenomenon with road biased tyres sir... No one has an answer yet |
26th Jan 2014 10:16am |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
Thanks for the replies. I am learning with your help… slowly!
26th Jan 2014 10:30am |
Ahh, more info... Send it back to the dealer as it could very easily be diff related... What makes you think it's OS or NS anyway? |
26th Jan 2014 10:34am |
When the noise comes on/80 on the needle... to hear it more clearly, I've got to lean over the steering wheel towards the windscreen. To my ears, it's coming from the offside area and I've asked a passenger to lean forwards too and they say they can't hear it from nearside. Add to that the items replaced at points B & C (mentioned in my last post) and the fact that the offside 'S'/teeth look a little dog eared, I'm leaning towards the offside.
26th Jan 2014 10:47am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8662 |
driveshaft end does look quite shiny and new on the pic, could be that its had that side replaced at some point.
26th Jan 2014 4:12pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 |
my 2p worth.
26th Jan 2014 5:50pm |
Okay... Went for motorway drive this afternoon and the noise came on with the needle at 80mph.
26th Jan 2014 6:14pm |
could it be at all possible, that you paid for a drivers side hub repair, but as pictured got instead a passengers side repair. thus the remaining noise, and new fitted locknut 'evidence' your invoice will prove your intentions/diagnosis.
6th Feb 2014 11:56pm |
@johnboy - Thanks for the observations. Tbh with you when I took the front pass wheel off and saw the shiny hub nut, my first obvious thought was, they've done the nearside and accidentally referred to it as the offside. That said, at the time, it was the main dealer Master Tech who took me round the car after that and other work had been done and he was instinctively pointing towards the offside as he referred to the offside area.
7th Feb 2014 10:50pm |
