![]() | Home > Maintenance & Mods (L322) > Pictured - Is it the Wheel Bearing? |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
ok, just ask them if they would normally replace the lock seal, or tap it back to relock etc. (either way would do for me, but not my car. ) but it looks like one is new!
So, the 'friend of the family' mechanic road tested and inspected the SC today. Verdict:
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
It's the forum, makes you paranoid |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35659 ![]() ![]() |
..................and relax...
I'm learning that you will always find something wrong if you look.......
@ NMJ, you're right.
hmm, if you think that the tyres ARE noisy, but you think its coming from a particular wheel/corner, then maybe switch it to another corner of the car and give it a run. I had a tyre that wouldn't balance properly, and by switching it it went away. (to the back) just check that your tyres are not rotational, if so, just move same side from front to rear.....you might need your spare wheel out if you haven't got two jacks etc. -or just throw the spare on! got to be the easiest way of finding a tyre issue.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
Told you at the beginning sir |
You did Sir... when the fronts discs and pads get replaced next Sat, providing the tyres are of a suitable type to do so, I'll get the front wheels swapped over to see if that makes any difference/ shifts the noise and then we'll know if it's the tyres or not.
I know ill be slammed for saying this but, think seriously about weather the stopping distances etc etc will be affected by the lesser brand Nexian tyres? Don't think id'e put them on mine! |
All noted Craig and I'm not sure if I'd buy them as "my choice" but... They do get good all rounder reviews and main dealers are selling A.U RR shod with them.
quote: 'and I had to emergency brake, steer away from the oncoming car, heavily mounting a kerb with the front nearside wheel' unquote.
