Home > Technical (L322) > Oil low pressure sensor
Petr
2007 Range Rover Vogue SE TDV8 Java Black
Hi guys!
Can someone clarify
If the range rover vogue l322 has absolutely no oil will the engine turn over?
Or will the low oil pressure switch prevent engine turnover to avoid engine seizing.
Kind of makes sense if there was this safety cut of device.
Look forward to your reply
Post #232868 4th Jan 2014 6:25pm
The sensor switch only detects when the pressure is low and doesn't act as a safety cut off device. If there is no oil in the sump it is possible for the engine to run for a short period of time before it seizes up due to lack of lubrication. Not recommended trying this though...
Post #232876 4th Jan 2014 6:59pm
adigorn
it does but there is none Big Cry
Post #232888 4th Jan 2014 8:33pm
The engine would have to have oil pressure loss for that system to work... But surely, oil pressure is lost everytime the car is turned off so, it would never start using that system would it? Neutral
Post #232970 5th Jan 2014 11:27am
