Home > Technical (L322) > Slow to restart
RR1234
2014 Range Rover Autobiography SDV8 Luxor
Slow to restart
After I have driven my RR for a while it is slow to restart - why?
All thoughts and suggestions of how to sort welcome.
Post #231110 23rd Dec 2013 7:38pm
Generally it's fuel pumps or injectors.
Post #231111 23rd Dec 2013 7:41pm
RR1234
Thank you. I've replaced two fuel pumps over the past two months. One in the fuel tank the other at the rear - one left to replace in the engine?
Post #231234 24th Dec 2013 9:44am
Why not bung in some fuel system cleaner before you start on the injectors?
Post #231242 24th Dec 2013 10:02am
adigorn
because the fuel cleaner is not going to fix the overflow issue
which is the most likely causing the starting problems
might be HPP problem as well however less likely
next step would be leak off test Thumbs Up
Post #231250 24th Dec 2013 10:17am
I had injector failure, but once it was running it ran ok on all 6 cylinders. It was just at the start that it didn't work. It also got progressively worse until it wouldn't start without easy start.
Injector cleaner may not fix it but the worst that can happen is you clean the other 5 injectors. It's the cheapest thing to try next.
Post #231263 24th Dec 2013 11:02am
adigorn
Ok but at the end of the day its pointless
no mater cheap or not
Post #231266 24th Dec 2013 11:32am
...er, based on what?
Post #231267 24th Dec 2013 11:33am
adigorn
On experience mostly
not to mention that magic potions spraying wd40 etc
is just a butchering prolonging failure of component
having nothing to do with actual fix
Post #231268 24th Dec 2013 11:37am
the OP says he has problems starting after he has been driving , so would that be an air lock possibly? ... - .- -.
Post #231270 24th Dec 2013 11:52am
adigorn
possibly
but if we will look at the problem as
difficult to start when hot (better on cold)
it may be inj overflow (so leak off test would give us some answers)
me thinks Thumbs Up
Post #231271 24th Dec 2013 11:56am
injector overflow as in ''a flooded carb'' ? ... - .- -.
Post #231272 24th Dec 2013 12:00pm
Not according to the many experiences of members on this forum, in the thread I referenced.
Who's mentioned wd40? Or even magic potions for that matter?
Stan, mine was terrible when hot. What was happening was the dodgy injector was de-pressurising the rail and sending the fuel back to the tank. Once it was up and running there was enough pressure to run ok. My only point is a cleaner may clear a blockage in an injector and is worth a try. If it doesn't then a leak off test is probably next port of call.
Post #231274 24th Dec 2013 12:20pm
understood David.. Thumbs Up
i would try the cheapest 'possible' solution first but then i'm a tight git... Laughing ... - .- -.
Post #231275 24th Dec 2013 12:25pm
adigorn
i understand
whats injector cleaner than in your opinion
technically approved solution
i am just trying to say if something is faulty needs a proper repair
not pouring chemical int the tank and prayer
if i understand correctly i am entitled to express my own opinion based on my own experiences
Post #231277 24th Dec 2013 1:01pm
