Home > Technical (L322) > Slow to restart |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Generally it's fuel pumps or injectors. |
23rd Dec 2013 7:41pm |
RR1234 Member Since: 29 Apr 2013 Location: Northern Ireland Posts: 55 |
Thank you. I've replaced two fuel pumps over the past two months. One in the fuel tank the other at the rear - one left to replace in the engine? |
24th Dec 2013 9:44am |
Why not bung in some fuel system cleaner before you start on the injectors? |
24th Dec 2013 10:02am |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 |
because the fuel cleaner is not going to fix the overflow issue
24th Dec 2013 10:17am |
I had injector failure, but once it was running it ran ok on all 6 cylinders. It was just at the start that it didn't work. It also got progressively worse until it wouldn't start without easy start.
24th Dec 2013 11:02am |
Ok but at the end of the day its pointless
24th Dec 2013 11:32am |
...er, based on what? |
24th Dec 2013 11:33am |
On experience mostly
24th Dec 2013 11:37am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35327 |
the OP says he has problems starting after he has been driving , so would that be an air lock possibly? ... - .- -.
24th Dec 2013 11:52am |
possibly
24th Dec 2013 11:56am |
injector overflow as in ''a flooded carb'' ? ... - .- -.
24th Dec 2013 12:00pm |
Not according to the many experiences of members on this forum, in the thread I referenced. Who's mentioned wd40? Or even magic potions for that matter? Stan, mine was terrible when hot. What was happening was the dodgy injector was de-pressurising the rail and sending the fuel back to the tank. Once it was up and running there was enough pressure to run ok. My only point is a cleaner may clear a blockage in an injector and is worth a try. If it doesn't then a leak off test is probably next port of call. |
24th Dec 2013 12:20pm |
understood David..
24th Dec 2013 12:25pm |
i understand whats injector cleaner than in your opinion technically approved solution i am just trying to say if something is faulty needs a proper repair not pouring chemical int the tank and prayer
if i understand correctly i am entitled to express my own opinion based on my own experiences |
24th Dec 2013 1:01pm |
