Home > Technical (L322) > Judder under own steam?
stuboy00
Scotland 2006 Range Rover Vogue SE Td6 Java Black
I've noticed that I'm getting a judder when I lift off the brake and let the range rover move off under its own steam any ideas?
Cheers guys F**K IT you only live once
Post #228689 12th Dec 2013 7:47pm
Have you touched the centre of all the wheels to see if any one is hotter than the others? Thinking it could be a brake binding. Previously..
Post #228692 12th Dec 2013 7:55pm
stuboy00
Pretty sure it's not a binding brake but I will give it a check was thinking something maybe a bit more sinister ie gearbox or transfer box? Hopefully not but I can't help but think the worst! F**K IT you only live once
Post #228694 12th Dec 2013 8:00pm
it might be the injectors being dirty or blocked..does it do it when you press the accelerator .. ... - .- -.
Post #228697 12th Dec 2013 8:05pm
stuboy00
I don't think so? The other half seems to think its doing it all the time? I will put injector cleaner through tomorrow and see what happens stan! But im not convinced that this is the problem? As it's only doing it as you lift the brake and it starts off under its own steam F**K IT you only live once
Post #228699 12th Dec 2013 8:11pm
my thoughts are that its running rough and only shows when on idle and in gear.. ... - .- -.
Post #228704 12th Dec 2013 8:16pm
stuboy00
Runs fine Stan no erratic idle? That's how I'm not convinced, sorry should have been more specific but like I said I shall try some injector cleanser tomorrow thanks Wink F**K IT you only live once
Post #228708 12th Dec 2013 8:21pm
RXWRR
United Kingdom 2010 Range Rover Vogue TDV8 Santorini Black
Judder like symptoms could also be down to an EGR temp sensor fault. Better to be irresponsible and right, than to be responsible and wrong.
2010 Vogue 4.4 TDV8 Santorini Black, Jet/Ivory interior
Post #228798 13th Dec 2013 7:53am
stuboy00
Ok guys so I've tried using injector cleaner but the problem is pesisting and is now even worse on idle it now runs very lumpy when you select reverse and ease off the brake it as if the brake is being pumped and the same when drive is selected until the accelerator is pressed? Could it be failing injectors? Cars got 145,000 on the clock F**K IT you only live once
Post #230558 20th Dec 2013 9:37pm
