![]() | Home > Technical (L322) > Judder under own steam? |
stuboy00 Member Since: 09 Feb 2012 Location: Glasgow Posts: 251 ![]() ![]() ![]() |
I've noticed that I'm getting a judder when I lift off the brake and let the range rover move off under its own steam any ideas?
Pretty sure it's not a binding brake but I will give it a check was thinking something maybe a bit more sinister ie gearbox or transfer box? Hopefully not but I can't help but think the worst! F**K IT you only live once |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
it might be the injectors being dirty or blocked..does it do it when you press the accelerator .. ... - .- -.
I don't think so? The other half seems to think its doing it all the time? I will put injector cleaner through tomorrow and see what happens stan! But im not convinced that this is the problem? As it's only doing it as you lift the brake and it starts off under its own steam F**K IT you only live once |
my thoughts are that its running rough and only shows when on idle and in gear.. ... - .- -.
Runs fine Stan no erratic idle? That's how I'm not convinced, sorry should have been more specific but like I said I shall try some injector cleanser tomorrow thanks |
RXWRR Member Since: 30 Jul 2013 Location: Staffordshire Posts: 60 ![]() ![]() ![]() |
Judder like symptoms could also be down to an EGR temp sensor fault. Better to be irresponsible and right, than to be responsible and wrong.
Ok guys so I've tried using injector cleaner but the problem is pesisting and is now even worse on idle it now runs very lumpy when you select reverse and ease off the brake it as if the brake is being pumped and the same when drive is selected until the accelerator is pressed? Could it be failing injectors? Cars got 145,000 on the clock F**K IT you only live once |
