Home > Technical (L322) > TDV8 4.4 Vogue - aux heater?
Page 2 of 3 <123>
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
cheers for response
looks like the job for this weekend is to fetch it out and try to sort it before the next cold snap
Post #229085 14th Dec 2013 10:47am
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
If you have park heating (no fob) is it possible/practicable to retrofit remote functionality? 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #248553 16th Mar 2014 7:17am
Berty
England 2012 Range Rover Westminster 4.4 V8 Baltic Blue
I have a 2012 autobiography with the park heating remote yesterday morning -3 I used it and it seems to be blowing just cold air around, it didn't defrost the screen only the mirrors, no heat in the cabin and I used it on two cycles,although I could hear fans going and could smell fumes,but no smoke when I started the car the temp gauge was still clap cold to, which I understand it should warm the coolant a few degrees and move the gauge, anyone any ideas or similar problems? Thanks Berty
Post #415934 30th Nov 2016 8:11am
That sounds broken Berty.
The way to check it is to run a cycle it should start the fans, then start the heater fan, then prime the burner, then kick up. at which point you should be able to hear a quiet ticking from the pump at the rear of the car. It should take about 60 secs to get up and running at the most.
It will take a little time to warm the coolant through and probably won't display much change in temp on the dash. There is nothing that can't be fixed with a hammer😜😜
Post #416053 30th Nov 2016 8:00pm
The engine temperature gauge won't show anything because the engine is isolated out of the coolant loop when the FBH is running alone . If it wasn't all that would happen during the FBY cycle is the the engine block would take all the heat for a net gain of a couple of degrees . 2008 MY Supercharged
Post #416117 1st Dec 2016 1:43am
TomCobbly
Does anyone know if there is a service interval for the FBH? I'm thinkig of things like changing the air filter or cleaning the glow plug/flame sensor and injector? I can imagine things getting pretty clogged up if the air flow gets restricted Shocked 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #416169 1st Dec 2016 2:46pm
no service interval for them. they are pretty clean burning if running correctly. They are easily accessed though, just the inner arch liner which needs to come off. then the hoses can be clamped and the unit removed. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #416193 1st Dec 2016 5:15pm
stefan063
Yugoslavia 2012 Range Rover Autobiography Black TDV8 Barolo Black
Kidcrew_bob wrote:
Thanks Fairwx - penny has finally dropped !!
Can you upgrade an early 4.4 with the improved gel battery (?) or is there software chages inviolved also???
TIA
I have EXIDE GEL battery. 100Ah. Working great. A bit expensive then normal batteries. Smile FBH work like a charm with remote
Post #416216 1st Dec 2016 7:12pm
stefan063
In what shape is you battery? Mostly everything depends on VOLTAGE,second air temperature and etc.... Check user manual. Everything says there...
Post #416217 1st Dec 2016 7:15pm
Rambles
About to install a varta AGM 105ah battery......
Very Happy Very Happy
Post #416243 1st Dec 2016 10:38pm
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
I’ve just pick up this thread....being a new owner Aug 18.....I’m looking to see if my 2011 VSE aux heater works. So far I get nothing out of it. I can only change the set time but I don’t have a remote fob. Do I need a remote fob?
Seems to be a disappointing feature if it doesn’t work! Any ideas guys?
Regards
Mark
Post #503589 1st Feb 2019 2:57pm
mjdronfield
Manual via fob is an option I think. It’s fitted to help the car warm up on cold days. It’s not a disappointing feature. You being able to set it to come on is just part of what it does....
That said, it only runs for about 20min and warms the interior slightly and demises the windows. I’ve never noticed the temp gauge being any different when I start the car though.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #503593 1st Feb 2019 4:08pm
nambFFRR
Does anyone have any pictures or diagrams to show where the heater is located on a 2011 Vogue SE?
I get no heat anywhere just fan noise. The build sheet says it’s fitted and it should have a remote fob (didn’t come with the car!). I don’t know which one to purchase.
I can set the aux heater on the climate function on the touch screen
Can anyone help??
Regards
Mark
Post #503717 2nd Feb 2019 7:09pm
mjdronfield
It’s under the passenger side wheel arch, sort of under the battery location. There should be a little exhaust sticking down there too. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #503719 2nd Feb 2019 7:19pm
nambFFRR
Thanks for the location....I’ll have to have a look.....no idea why it doesn’t work. Do I need the remote as well?
Post #503720 2nd Feb 2019 7:22pm
Page 2 of 3 <123>
