![]() | Home > In Car Electronics (L322) > HID Bulbs |
markdotreed Member Since: 05 Sep 2011 Location: Ropley Posts: 741 ![]() ![]() |
Without meaning any disrespect to our site sponsors I've been doing some digging on the price of HID bulbs and find that it's genuinely a complete minefield out there and was wondering what the consensus was on how much you need to spend for a replacement HID Bulb.
Hi,
Thanks for the Link, I tried many searches before I posted this up and still didn''t find that !!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35526 ![]() ![]() |
OE bulbs are usually osram which are made in germany and philips probably made in europe somewhere , whereas the cheaper ebay bulbs are chinese hence the difference in price..
Gruute Member Since: 05 Jul 2012 Location: Flanders Posts: 136 ![]() ![]() |
Why not go for an upgrade with these?
The '2 for £32' arrived this evening and are labeled 'Phillips' and 'made in Germany'
did you get the 6000k ones Mark? ... - .- -.
Yep. They certainly look the part. Regards
the OE 4300k xenons are good but the slight increase in temperature does make a difference...this upgrade will probably be one of my next jobs.. ... - .- -.
That's video clip appears to show quite some difference with the Nightbreaker... The OP got 2 x Philips bulbs for £32 & the advert for the Nightbreaker shows £60 for one bulb. |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
Yep, there not cheap that's for sure. And the bulb Gruut mentions is the D2S, the D1S fitted in 2006/9 cars is even more expensive at £70 a bulb. But if the difference is as marked as in the video then there certainly impressive.
Looking at the video clip more closely I reckon the side by side clips are from 2 different camera's. So its possible the dramatic difference is more down to the video camera than the bulbs. The video on the left showing the Night Breaker Unlimited seems of much higher quality and its very likely that the night time capability is also far better, making the comparison unfair. |
JackRegan Member Since: 20 Oct 2012 Location: Wirral Posts: 241 ![]() ![]() |
Not having much experience with HID bulbs, when one went in the FF I thought to save time I'd pop in to Halfords as I was passing. Well to say I was shocked when I found they wanted £70 for ONE. When I got home I went on the bay and found they could be had from around £15 so I ordered a couple and replaced both.
i suspect you have the wrong type of bulb there..i made a mistake of buying that type and having trouble fitting it resulting in damaging the holder..
