Home > In Car Electronics (L322) > HID Bulbs |
markdotreed Member Since: 05 Sep 2011 Location: Ropley Posts: 741 |
Without meaning any disrespect to our site sponsors I've been doing some digging on the price of HID bulbs and find that it's genuinely a complete minefield out there and was wondering what the consensus was on how much you need to spend for a replacement HID Bulb.
28th Nov 2013 9:46am |
Hi,
28th Nov 2013 10:27am |
Thanks for the Link, I tried many searches before I posted this up and still didn''t find that !!
28th Nov 2013 10:41am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
OE bulbs are usually osram which are made in germany and philips probably made in europe somewhere , whereas the cheaper ebay bulbs are chinese hence the difference in price..
28th Nov 2013 10:49am |
Gruute Member Since: 05 Jul 2012 Location: Flanders Posts: 136 |
Why not go for an upgrade with these?
28th Nov 2013 6:35pm |
The '2 for £32' arrived this evening and are labeled 'Phillips' and 'made in Germany'
28th Nov 2013 6:47pm |
did you get the 6000k ones Mark? ... - .- -.
28th Nov 2013 7:09pm |
Yep. They certainly look the part. Regards
29th Nov 2013 6:34am |
the OE 4300k xenons are good but the slight increase in temperature does make a difference...this upgrade will probably be one of my next jobs.. ... - .- -.
29th Nov 2013 8:57am |
That's video clip appears to show quite some difference with the Nightbreaker... The OP got 2 x Philips bulbs for £32 & the advert for the Nightbreaker shows £60 for one bulb. |
29th Nov 2013 10:21am |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
Yep, there not cheap that's for sure. And the bulb Gruut mentions is the D2S, the D1S fitted in 2006/9 cars is even more expensive at £70 a bulb. But if the difference is as marked as in the video then there certainly impressive.
29th Nov 2013 10:31am |
Looking at the video clip more closely I reckon the side by side clips are from 2 different camera's. So its possible the dramatic difference is more down to the video camera than the bulbs. The video on the left showing the Night Breaker Unlimited seems of much higher quality and its very likely that the night time capability is also far better, making the comparison unfair. |
29th Nov 2013 10:55am |
JackRegan Member Since: 20 Oct 2012 Location: Wirral Posts: 221 |
Not having much experience with HID bulbs, when one went in the FF I thought to save time I'd pop in to Halfords as I was passing. Well to say I was shocked when I found they wanted £70 for ONE. When I got home I went on the bay and found they could be had from around £15 so I ordered a couple and replaced both.
30th Nov 2013 10:35pm |
i suspect you have the wrong type of bulb there..i made a mistake of buying that type and having trouble fitting it resulting in damaging the holder..
1st Dec 2013 9:44am |
