Home > In Car Electronics (L322) > digital tv installation |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
You will have to break into the power lines going to the other AV kit - purple and brown IIRC, or run cable across to the rear fuesbox, all depends if you want pre-ignition on power (always powered) or post-ignition on power.
27th Nov 2013 7:43pm |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 |
Yes I've installed the kit from Parkmyauto. From what I remember it was relatively easy to install and the instructions where reasonably clear. I can't quite remember what the procedure was with the power - I 'think' the instructions tell you which cable it was - but I found Russell extremely helpful - if you email/call him before you buy he will tell you how it all wires up.
28th Nov 2013 9:01pm |
sikegan Member Since: 21 Aug 2011 Location: Limerick Posts: 4 |
have emailed Russell but would appreciate any help you can give |
28th Nov 2013 10:54pm |
